Author Topic: Alternator Up Grade 32amps  (Read 103751 times)
Offline anders288
« on: February 07, 2013, 12:04:35 PM »
  Hi
I have been working on a 32amps and 45amps Alternator up grade. The 32amp one is ready for road testing.
The 45amp one still need a few thing dune to it. The stock rotor weights 5 lbs 12 oz the 32amp rotor weights
2 lbs 4oz.
« Last Edit: September 12, 2013, 02:47:01 PM by Gordon »
Offline iron_worker
Re: Altenator Up Grade 32amps
« Reply #1 on: February 07, 2013, 12:09:49 PM »
Wow. This is very cool.
How much do you expect this kit to cost? (assuming you're planning to sell)
What is roughly the ouput of the stock alt?
IW
« Reply #2 on: February 07, 2013, 12:17:48 PM »
IW
Yes, agreed.
I have the same questions.
Offline anders288
« Reply #3 on: February 07, 2013, 12:26:13 PM »
IW
  The stock alternator out put is 17amps. not sure how much it will cost yet. It Will be flywheel
        stator
        stator mount
        crank taper adapter
        regulator
        new regulator plugs
        new wiring
        installation
Offline Ricky_Racer
« Reply #4 on: February 07, 2013, 01:00:48 PM »
Anders, can the alternator cover be shortened with your planned kit? Thanks. RR
Offline anders288
« Reply #5 on: February 07, 2013, 01:11:00 PM »
As you can see in the photo there is a lot of space in the cover and a differant space used with a differant cover
the stock cover walls are papered end the mount holes location for the stator is critical
I think the 32amp alt will work on the 500,550,350 and 400 also.
« Reply #6 on: February 07, 2013, 01:18:31 PM »
If these will work with a shortened cover i'm in for sure, I need more output for my fuel injected 1000cc build.... 8)
Also, i can't believe, with all the talent on this forum, that this hasn't been done as a kit already.... :o
Offline Ricky_Racer
« Reply #7 on: February 07, 2013, 01:23:48 PM »
Thanks, Anders. If this kit doesn't require machining the crank snout and will also fit into a reasonable budget, I'm definitely interested as well. RR
« Reply #8 on: February 07, 2013, 01:25:07 PM »
RR: Couldn't the stock cover be modified with a tapered panel welded on the edge closes to the pavement. A completely fresh cover would be a handful to create, getting the placement of the holes, etc.
As to why it hasn't been done already, maybe its a technology thing?
To the extent anders would feel comfortable doing so, I'd like 20 words or less on how it works and why now rather than ten years ago?
Offline anders288
« Reply #9 on: February 07, 2013, 01:26:15 PM »
If these will work with a shortened cover I'm in for sure, I need more output for my fuel injected 1000cc build.... 8)
      I'm sure you have herd the one about time and money.
« Reply #10 on: February 07, 2013, 01:36:19 PM »
Yes, but some of us don't care.... ;D   Have you seen the billet blocks Mike Reick is making..? {i have one of those as well...}  :P
Offline anders288
« Reply #11 on: February 07, 2013, 01:43:23 PM »
          An Alternator  out put is mainly controlled by it's magnetic field and it's almost imposable to pull the stator out of the
         flywheel and if the end of you finger gets in between the cover and engine when it's being install  your going to need a bandaid.
          And it only weighs 2 lbs 4 oz
Offline anders288
« Reply #12 on: February 07, 2013, 01:44:31 PM »
Do you have any performance curves or duty cycle info on the unit?  Conversion efficiencies?
At what RPM is that 32 amp peak?
      Max out put 5K
« Reply #13 on: February 07, 2013, 01:46:34 PM »
No need to create another cover Ron, just cut some out of the original cover and tig it back up, seen it done before mate.... ;)
Offline anders288
« Reply #14 on: February 07, 2013, 01:47:18 PM »
        Yes I have seen  Mike's bike I'm going to install one on his bike
Offline anders288
« Reply #15 on: February 07, 2013, 01:53:19 PM »
               I would want to have a rigid welding  fixture to hold everything in place if I was going to do it.
« Reply #16 on: February 07, 2013, 02:51:30 PM »
Let us know as soon as you have an idea of pricing... ;)
Online MRieck
« Reply #17 on: February 07, 2013, 03:48:23 PM »
Yup....that's the plan. Anders has been over my house several times. He is a great fella with a huge amount of bike knowledge. He has dedicated a good amount of time to this project. He has other good ideas too but....time and money. ;D ;D ;D
« Reply #18 on: February 07, 2013, 04:00:13 PM »
I have seen the rotors and spacers that Anders has been machining and its very good quality and well worth the money -  Ill be road testing the rotors once the snow melts. Cant wait! Anders has a lot of talent...
cheers
Andy
Online MRieck
« Reply #19 on: February 07, 2013, 04:02:50 PM »
It is sobering when that cover is grabbed by that magnetic force. ::) I hate messing with modern alternator covers.
Offline faux fiddy
  • bike in a box
« Reply #20 on: February 08, 2013, 04:20:53 AM »
2 lbs 4oz.
That's a pretty significant weight loss. Anyone racing these things would want one unlesss they go straight discharge and remove it all.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Online MRieck
« Reply #21 on: February 08, 2013, 07:39:12 AM »
Quote from: rotortiller link=topic=117735.msg1329677#msg1329677 date=1360316985
RT
PS[quote
Most of us expect you intend the thing to run at least a full tank of fuel.  :)
Many common bikes today run 30-40 amp alternator ratings.
[/quote]
 The biggest problem is getting a reg/rect to handle the extra without overheating. The first generation hayabusa's had a problem with overheating. Guy's are switching to ZX-14 parts.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #22 on: February 08, 2013, 09:54:53 AM »
This dovetails nicely with Mooshy's post about using heated clothing. With an upgrade like this running a heated vest should not be a problem.
« Reply #23 on: February 08, 2013, 10:06:15 AM »
Exactly!
