Author Topic: Install new / used motor  (Read 896 times)
Offline bultaco59
« on: February 08, 2013, 07:14:28 AM »
Good Morning Gentlemen,
Im going to be installing my new / used motor hopefully this weekend and I am going to rebiuld the carbs, does anybody know jet sizes, for four into one pipe, and pods
I will installing these, and I want to get as close as possible, I would like to get it
running, so I can get it to the shop for valve adjust. timing, tune up, so I can
pull the motor back out and start my cafe project. motor first.
ps its a 78 cb 750k
bob in burbank
Offline goldarrow
  • one day, i'll be an
Re: Install new / used motor
« Reply #1 on: February 08, 2013, 07:19:50 AM »
If you can pull the motor off and back on, tinkering with carbs, then you can perform the tune up, timing, etc. yourself, only need the manual, no need to bring to shop and spend your money.
I'm in panorama city.
CB550 K0
Offline Stoli
« Reply #2 on: February 08, 2013, 10:07:56 AM »
There is no formula for jet sizes when you switch from the stock airbox and exhaust. Even if you specified the kind of exhaust and pods you are putting on (there is a difference between EMGO and K&H pods), each bike is a little different so what works for one may not be ideal for another.
If you do a little research, you will find that your '78 K carb (assuming it is stock) came with 110 jets and in general, adding pods and a 4 into one exhaust will require an increase in 2 or 3 jet sizes, so 120 or 125 jets would probably be a good place to start. That will only address the high end rpm range however. For the mid range, you will probably have to shim your needles (the '78 carb needles are not adjustable so you will need to add a couple washers to each needle to lift them). Boring out the pilot jets may also be required to get the mixture right. Hondachopper.com has some good info regarding the necessary adjustments to the '78, including details on boring out the pilots.
If I were starting the engine after a rebuild for the first time, I would put a stock airbox and 110s on it and go through a complete tune up (idle adjust, timing, carb balance...) to set a baseline, then throw your pods on and make the needle and jet adjustments, then re-tune for idle again and go out and do a few plug chops in the mid and high rpm range to see where your mixture is at.
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #3 on: February 08, 2013, 10:29:31 AM »
^ what he said and 122.5 jets are about a .051 drill.  Idle jets are seldom effected, shimming the needle does more good than anything.
