Author Topic: media blasting  (Read 684 times)
Offline bultaco59
media blasting
« on: February 08, 2013, 09:52:47 AM »
Good morning again,
I will be having some parts media blasted, and I was wondering has anyone ever
media blasted their motor, it doesnt sound healthy for the motor, but can it be done. ?? thoughts??
bob in burbank
Offline Elan
    • Vital Motor Parts
Re: media blasting
« Reply #1 on: February 08, 2013, 10:08:59 AM »
I , like most, will say no. yes its physically possible, but its risky. that media gets EVERYWHERE, and any particles finding a way to sneak into the motor is obviously bad news.  Even if you wrap it up great, just unwrapping can cause particle to enter. If you reaaaaly want to, i would at least do soda blasting.
76 750k
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: media blasting
« Reply #2 on: February 08, 2013, 10:26:04 AM »
Glass bead blast for a nice satin look.  Sand is a bad idea, too abrasive and sticks to parts only to fall off later.  I would remove all parts to be blasted.  No point in blasting main cases, they can be cleaned and touched up easily.
Offline goldarrow
  • one day, i'll be an
Re: media blasting
« Reply #3 on: February 08, 2013, 10:55:38 AM »
if you feel blasting is needed, go with soda.  soft enough to pretty much clean anything, safe for the motor, and easily clean and wash off.  HF sells them 50 lbs bag for $40 i think.
CB550 K0
Offline iron_worker
Re: media blasting
« Reply #4 on: February 08, 2013, 01:21:59 PM »
Had my engine cases all glass beaded. However, I stripped my cases completely down so there was no internals then reassembled. I then made sure all bearing surfaces were protected (such as final drive bearing surface) with duct tape or holes filled with a bolt, etc etc.
If you glass bead you will pretty much have to tear down the motor to completely clean it out to remove all the dust/grit.
IW
Offline RSchaefer
Re: media blasting
« Reply #5 on: February 08, 2013, 04:43:42 PM »
Did soda blasting on mine and repainted, no problem.  did get some soda in the crankcase but washed it all out w/gas.  In any case any extra soda will burn off easily.
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline pickle fart
Re: media blasting
« Reply #6 on: February 08, 2013, 07:38:10 PM »
Dry ice blasting. It's beautiful, the dry ice evaporates leaving only a light dust from the dirt and grease or corrosion. I've had some transmission parts done and a boat motor done in place. Check your yellow pages.
Offline harisuluv
Re: media blasting
« Reply #7 on: February 08, 2013, 10:18:01 PM »
Just wanted to add that if you do a simple google search for something like "harbor freight coupon" you can find a printable 20% off any one item pretty much going on all the time.  When I need a bag of soda I print one and instead of $37 you can get the 50 pounder for 30.xx.  Hope that helps.
