Author Topic: CB 550 carb question  (Read 3128 times)
Offline Ghostbuster
Re: CB 550 carb question
« Reply #25 on: February 16, 2013, 11:04:53 AM »
Double checked the float height 22mm. Regarding the main jets I positioned them with the small hole upwards (when mounted on the bike) (just like the old ones)
Where on the carbs can i see what type they are?
Offline Deltarider
« Reply #26 on: February 16, 2013, 11:36:13 AM »
Here
CB500K2-ED Excel black
Offline Ghostbuster
« Reply #27 on: February 19, 2013, 09:10:44 AM »
Hi again, had a look at the carbs this weekend, they are officially 022A, does that make sense on a 75' 550?
Offline Deltarider
« Reply #28 on: February 19, 2013, 09:57:26 AM »
Yep. So official setting for yours is found on p 165. of the Honda Shop Manual 500-550. But not even Honda is perfect. They made a mistake over the left column. 500 should be read as 550. So officially it is 4th groove for the 550, (3rd for the 500).
« Last Edit: February 19, 2013, 10:04:15 AM by Deltarider »
Offline Ghostbuster
« Reply #29 on: February 19, 2013, 10:01:02 AM »
Ok, well like i said earlier I think that the next step for me will be to take the bike for ride and pay close attention to my spark plugs. Now that I have the needle in 3'rd grove I will start my run on D8EA spark plugs as a beginning.
I'll let you know how the bike runs, when spring comes  8)
Offline Deltarider
« Reply #30 on: February 19, 2013, 10:05:36 AM »
You could enrichen a bit by turning the airscrews in a bit.
Offline Ghostbuster
« Reply #31 on: February 19, 2013, 10:13:34 AM »
Thanks, I'll try that, I, honestly, had forgotten all about this possibility for enrichment!
Offline Ghostbuster
« Reply #32 on: May 14, 2013, 12:49:17 PM »
So the weather is here, and I have taken the bike for a couple of testruns. To summarize i installed new needle/tube, mainjet and slow jet:
Main: 100
Slow: 38
Needle set in grove 3
I run with sparkplugs a "number" colder than standard.
The bike started pretty easily (not a small thing for a hobby.mechanic).
1. test-run (10 miles). Well the bike doesn't die any more when its drives at slow speeds and gets a little throttle. If I fling the throttle very fast to full throttle it does hesitate a little (is this normal?).
When I got home i looked at the spark-plugs. They were gray. From what I know this isn't a disaster, they were definitely not white.
2. test-run (80 miles). Bike ran very good, I've noticed that after my carb rebuild it now very good to go slow in high gears :) When I got home i noticed a very slight brown tan on the spark plugs.
So all in all i'm very happy. It might run a little bit on the lean side (I guess that grove no. 4 or "3,5" would also be ok for the needle), but it's 100 times better than before.
By the way, I ran the test runs on shell v-power, if that s counts for anything.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #33 on: May 14, 2013, 02:32:05 PM »
A slight hesitation when you whack the throttle open is normal. These carbs don't have an accelerator pump, so it takes a second for the fuel flow to catch up with the throttle opening.
