I asked this same question a month or so ago
http://forums.sohc4.net/index.php?topic=117060.msg1322035#msg1322035I also just recently rebuilt my engine so i think I might be able to help you out.
(bottom picture from left to right, my best guess here so work with me)
First: Kick starter
Second or third: Gear change
Fourth: I def. know that's the points seal, the metal edge sits next to the crank shaft.
Fifth: 91256-069-651, If that's the smallest, that should be the tack seal on top of the cam cover.
