Author Topic: Petcock fuel line brass pipe came out, what now?  (Read 999 times)
Offline jas67
« on: February 17, 2013, 09:31:05 AM »
The brass "pipe" that the fuel line attaches to came out of the petcock, instead of the fuel line coming off of it.
Can this be fixed, safely and reliably?    Or do I need to replace the petcock  :(
Classic Honda:
1976 CB400F
1975 CB400F (project)
1975 GL1000
1968 CL175 (1 nice one, one project)
1967 CB77
1967 CB160 (2 of 'em, both projects)
1967 CL160 project
Triumph: 2017 Thruxton R
BMW: 2016 R1200RS, 1975 R90S, 1973 R75/5, 1980 R100S
Ducati: 2013  Monster 796, 2013 848 Evo Corse SE track beast, 1974 750GT, 1970 Mk3d 450, 1966 Monza 250
Moto Morini: 1975 (titled 1976) 3 1/2 Strada, w/ Sport clipons.
Moto Guzzi: 2017 V7III Special,  1977 Le Mans, 1974 Eldorado
Offline HondanutRider
Re: Petcock fuel line brass pipe came out, what now?
« Reply #1 on: February 17, 2013, 09:34:13 AM »
Put it back in, applying a bit of threadlocker-red.  Tap the end gently with a mallet to firmly seat yet not distort.  No sweat.
« Reply #2 on: February 17, 2013, 09:40:12 AM »
The brass was "press fit" into metal housing originally.  Repeating that process out to restore it.  Sometimes if you gently twist it in its resting place hyou can find the position it was in before it got yanked out.  That will be the best position to press it or tap it back into place.  However, if you cannot find that position and the tube or socket has ovaled, you will need some sort of fuel resistant sealant.
Offline jas67
« Reply #3 on: February 17, 2013, 09:41:39 AM »
Thank you both.    I'll have to get some red locktite and try it.
Classic Honda:
1976 CB400F
1975 GL1000
1967 CB77
1967 CL160 project
« Reply #4 on: February 17, 2013, 09:45:40 AM »
 Should be a slight taper on both parts, make sure its clean..gentle tap to reseat it..
