Author Topic: Check out the carbon headlight I made for my CB750  (Read 7381 times)
Offline CarbonGuy
  • Good Things Happen on a Honda
Re: Check out the carbon headlight I made for my CB750
« Reply #25 on: February 28, 2013, 12:02:58 pm »
Just got done polishing the front end.  Looks nice but dang it is a bunch of work.
Offline CarbonGuy
« Reply #26 on: February 28, 2013, 12:10:41 pm »
The motor mount hasn't cracked yet.  I did structural on it and it is showing the carbon fiber is 48% stronger than the metal ones I took off it.  A structural part is more difficult than a cosmetic part.  The autoclave heats up longer and more pressure is needed.  The layup is different as well as you want the weave to build strength.  The good thing about carbon is it will take the harmonics much better than metal.  It is less weight, but minimal.  It is really about the look regarding this part. Just had to do it and the engineering is a fun thing to do if you like math.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #27 on: February 28, 2013, 12:58:18 pm »
This is not addressed at Carbon guy, really not. You have great skills, mean it.
So I can see where this stuff fits the look and feel of late 90's to our day's sport bikes,
In the context of sohc's I really detest the stuff, it's just the wrong fit, creates a material mish-mash that doest work on 70's stuff (for me, for me). Am I all alone in not going gaga about carbonized sohc's?  Take into account that i am a bit of a purist. Even "billet" stuff and 17" rims have no place on sohc's IMHO.
TG,a Mike Rieck billet cylinder no place! C'mon man!! I agree somewhat,but if it's not original,I think it can be blended well!We'll see cause I'm looking at the chainguard as we speak.Just waiting on headlight shell #1,both going on Calendar Girl! Also from Mr.FB ,waiting on a clear pts cover...enroute!!! Yippie Kai Ai or something like that! How's the racing going,we miss you.Bill
BentON Racing Website
BentON Racing Facebook
« Reply #28 on: February 28, 2013, 01:34:03 pm »
Like the way you did the center of the front hub. That stock? It's looking good.
Online RAFster122s
« Reply #29 on: February 28, 2013, 01:51:36 pm »
So, with that carbon rear fender it really begs to have a light rear tail-lamp assembly and new relocated turn signal stalks to that bracket so you have room for a set of rear panniers if you want to do a little touring.
Carbon fiber fairing like the Vesco Rabid Transit?  It is a classy fairing design.
That would be a ton of work...
The frame mod to make head removal easier on the CB750 in carbon would be a nice mod.
David
« Reply #30 on: February 28, 2013, 02:47:07 pm »
Any chance of doing an engine mount kit ?    8)  How about a carbon K model tank... ;D, is the resin you use fuel resistant..?
Its not that hard when you know what you are doing, i have a couple of friends that used to make their own race fairings fo4r their track bikes... ;)
Offline CarbonGuy
« Reply #31 on: March 04, 2013, 07:29:42 am »
The motor mounts I did consist of 3 parts.  I could do a tank, but you would have to send it to me and it would take some time.  I did a Suzuki GSXR1000 working tank for a guy and had no issues with contamination.  I tested the fuel every two weeks and sent it to a lab to see if it was getting contaminated.  I did it with three different fuels all from VP, oxygenated and non oxygenated over a three month time frame.  It took me three different resins to find one that did not interfear with the fuel.  The tank was stupid light and we put a Newton cap on it.
Offline laminaytrap
    • Satchealous Garage
« Reply #32 on: March 04, 2013, 08:29:09 am »
The only problem with bladderless carbon tanks is if you go down you do so in a fireball. For all it's strength carbon is also brittle. Kindof like tempered glass or carbide. A steel tank will dent and deform, carbon will crack and leak gas on your motor. I think on a bike you must have a bladder. Or a cage around it.
Having said that carbon stuff is awesome. And for an OEM+ build i'd say no, but for street/race/custom do it up.
I'm no purist though, thus I have a k7 and nobody really cares that I'm changing it.
Offline CarbonGuy
« Reply #33 on: March 13, 2013, 08:35:45 am »
Just finished polishing the hubs and they are going to mate with powder coated matte black wheels.
Offline srbakker
  • Spam & Eggs
« Reply #34 on: March 13, 2013, 12:57:57 pm »
Am I missing something or did you mill the fins off the middle of that hub?
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
Online RAFster122s
« Reply #35 on: March 13, 2013, 01:19:20 pm »
Yes Ghostrider, those fins are gone and the spoke flanges are trimmed to make them vertical ribs...
Hopefully the additional cooling area of the fins was not needed for the drum brake cooling.
David
Offline CarbonGuy
« Reply #36 on: March 14, 2013, 09:23:00 am »
I did mill the fins.  This is an everyday rider and the cooling shouldn't be an issue unless the clearances are out of whack due to wear and tear.  If you are on top of your maintenance the fins have zero benefit.  However, if this turns out to be an issue I will report on it so others learn from my mistake.  Once the wheels get back I will shoot you some pictures, but the finished piece should look nasty.
« Reply #37 on: March 14, 2013, 12:14:03 pm »
Don,
Got the Montgomery email today. The new stuff looks killer! What's next?
    • BentON Racing
« Reply #38 on: March 14, 2013, 12:39:24 pm »
Small and round!!! ;) ;D Bill
Offline CarbonGuy
« Reply #39 on: March 14, 2013, 12:42:17 pm »
Great hint Bill.
Offline CarbonGuy
« Reply #40 on: May 30, 2013, 07:54:25 am »
Just clear coated my clutch cover for my CB750.  I got this new clear coat in a can.  Simple to do and the entire can was $25.  It is a 2 part clear coat in a can from spraymax.  Check it out as it is the best clear coat money can buy that the average guy can do without having to take the part to a autobody shop.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #41 on: May 30, 2013, 09:25:57 am »
Diggin the carbon there Carbonguy, excellent work. I'll be in touch when I'm ready to carbonbling my ride!  8)
Where in Florida are you?  ???
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline CarbonGuy
« Reply #42 on: May 30, 2013, 09:33:28 am »
I am from Orlando, but work in Dayton, Ohio.  Let me know when you want to cloak your bike in carbon.  I have made some ground on my own CB750 and will share photos soon.  It looks wicked.
« Reply #43 on: May 30, 2013, 09:42:45 am »
I work in Orlando but I'm from just North of Dayton! Grew up in Bellefontaine and went to High School in Lima. Might be coming through Dayton in June to visit my folks.
TAMTF...
Wilbur
Projects:
Offline CarbonGuy
« Reply #44 on: June 03, 2013, 10:06:51 am »
Anytime you want a tour of the carbon lab let me know.
Offline Sprocketwerx
  • I'm just a motorhead, can't leave nuthin alone!
  • I like 'em fast and clean
« Reply #45 on: June 05, 2013, 06:58:54 am »
David
I can attest the fins gone is not a problem unless you're abusing the brakes.
My "72 was chopped in '73. Hub fins milled, hub and brake plate chromed, no prob after 40 years of hard use.
Dan "Sprocket" Harris
Sprocketwerx Motorsports
Offline CarbonGuy
« Reply #46 on: June 10, 2013, 06:20:34 am »
Here she is all put back together cloaked in carbon.
  • Moderator
« Reply #47 on: June 10, 2013, 09:15:24 am »
 8) 8) 8) 8) 8) any idea what the weight is ?
Sam. ;)
« Reply #48 on: June 10, 2013, 03:28:12 pm »
Looks great Don.... ;)
Offline SF
  • I burn gas very well
« Reply #49 on: June 10, 2013, 04:51:11 pm »
nice bike! is that original paint?
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
