Caps are about 3 weeks old, anyway I swapped sides on the condensers and the problem rested the same, so it wasn't electrical.
I changed the plugs and voilà! The bike fires on all 4's and at the first try it doesn't even need the choke or any thing.
If it doesn't need any choke went cold, it may be a symptom of a rich mixture. I found this post of yours in a different thread:
"This interests me, but I think my problem is different.
I've noticed that if I leave the petcock open with the bike off, number 2 carb starts dripping gas from the drain pipe, at first I thought the screw was loose, but it's not. I recently replaced the O-rings on all 4 of them."
You have a carburetor problem amigo.
I bet a cyber beer if you pull your new spark plugs, they are already turning black...
