Author Topic: Cylinders firing, but with a gap!  (Read 5591 times)
Offline Bailgang
  • Scott
  • Indiana
Re: Cylinders firing, but with a gap!
« Reply #25 on: February 16, 2013, 06:19:51 AM »
i'd just like to remind everyone that its not illegal to clean and reuse old fouled spark plugs,do it if you want.
Relax Dave its all cool, I didn't mean to make it sound like I was picking on you. :)
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #26 on: February 16, 2013, 12:21:33 PM »
ha!no its all cool bailgang!
Offline bjbuchanan
« Reply #27 on: February 16, 2013, 07:14:42 PM »
Check the resistance of your plug caps, perhaps whoever last worked on it decided to only replace what is necessary and now the old ones are played out?
Could be a lot of stuff really
Offline Jore
« Reply #28 on: February 19, 2013, 07:17:54 PM »
Caps are about 3 weeks old, anyway I swapped sides on the condensers and the problem rested the same, so it wasn't electrical.
I changed the plugs and voilà! The bike fires on all 4's and at the first try it doesn't even need the choke or any thing.
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
« Reply #29 on: February 19, 2013, 07:51:15 PM »
send the old plugs back to the factory for overhauling.
bollingball
« Reply #30 on: February 19, 2013, 08:00:28 PM »
Good now go get that plug cleaner and save your old plugs and use soda in it not sand. I have had one for many years they work great. But like TT said sharpen up the edges.
« Reply #31 on: February 20, 2013, 05:33:53 PM »
If it doesn't need any choke went cold, it may be a symptom of a rich mixture. I found this post of yours in a different thread:
"This interests me, but I think my problem is different.
I've noticed that if I leave the petcock open with the bike off, number 2 carb starts dripping gas from the drain pipe, at first I thought the screw was loose, but it's not. I recently replaced the O-rings on all 4 of them."
You have a carburetor problem amigo. ;) I bet a cyber beer if you pull your new spark plugs, they are already turning black...
Offline Jore
« Reply #32 on: February 20, 2013, 06:57:08 PM »
So, should I adjust my mixture?
1975 CB400F owner
« Reply #33 on: February 20, 2013, 07:09:44 PM »
The first thing I would do is check the actual fuel level in the float bowls, using the "clear tube" method. A search for "clear tube" should bring up detailed descriptions of the procedure.
Offline Jore
« Reply #34 on: February 20, 2013, 07:50:58 PM »
For that to work, I have to take the drain screws out and jam a piece of clear tube in to them right? Or, can I connect the clear tubes to the overflow pipes?
1975 CB400F owner
« Reply #35 on: February 20, 2013, 08:24:13 PM »
I believe for your carbs you must remove the drain plugs and jam/screw the tubes into the holes?
Offline Jore
« Reply #36 on: February 20, 2013, 08:41:12 PM »
Ok, there's some things I forget to mention:
1- Parts for these bikes aren't common here in Mexico, so I'm running the bike without a filter.
2- After warm up the revs seem to climb a bit, but go down once you give it some throttle.
1975 CB400F owner
