Author Topic: 1982 Honda CBX 1000 swing arm  (Read 2338 times)
Offline bruzer59
  • 1977 CB 750F
« on: February 15, 2013, 05:58:30 PM »
question...
 will a 1982 Honda CBX 1000 pro link swing arm fit on a 1977 CB750F  ?
Re: 1982 Honda CBX 1000 swing arm
« Reply #1 on: February 16, 2013, 06:38:40 AM »
I don't know but will you be going to a monoshock system or welding mounting points?
Offline toytuff
  • "watching the pinheads"
« Reply #2 on: February 16, 2013, 07:30:13 AM »
I would think another swingarm from a different bike would work better as far as modifaction.
A lot of parts go with the swingarm off a CBX.
tt
Offline Grabcon
« Reply #3 on: February 16, 2013, 07:52:22 AM »
I saw the round style CBX 1000 swingarm on eBay and it looks very similar to a CB900F.
I know from experience that the CB900F does require narrowing at the pivot, the pivot hole on the frame does require enlarging and you will need a pivot bolt made to fit. While doing the narrowing of the swingarm make sure that you have proper sprocket and tire alignment. I used the rear wheel of a CB1100F with the standard CB900F axle and spacers.
The CB900F is about 2" longer this may require additional shock length since shock angle is changed. I used the CB900F length which is 365 MM (14.37")
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
Offline Geeto67
  • A grumpy
« Reply #4 on: February 16, 2013, 10:23:55 AM »
if you use the79-80 cb750F swingarm all you should have to do is narrow it, it is the same otherwise dimensions as the 900F. I didn't think the 900F arm had a different pivot bolt.
Maintenance Matters Most
« Reply #5 on: February 16, 2013, 01:39:32 PM »
question...
Is this for looks or do you still want the bike to handle well.?  CBX arm will be too long and probably too wide..
