Author Topic: Checkin continuity on left hand control switches on on 76 CB550  (Read 891 times)
Offline CapeCafe
Can anyone help me with the correct method to check continuity on the left hand controls of a 76 CB550?  I have Hi/Lo Beam head light, right/left blinker and horn.  In following the CB550k wiring diagram it seems I should have continuity between:
White (Lo) - Br/R (head light) - Br/Wh (Tail light) when switched to Low beam
Blue (Hi) - Br/R (head light) - Br/Wh (Tail light) when switched to Hi beam
Light Grn (Horn) when grounded and horn button depressed
Light Blue (R signal)-Light blue/Wh when switched to right indicator
Orange (L signal) - Ornage/Wh when switched to left indicator
I refurbished the left hand controls and everything seems to be connected correctly, sliding smoothly and clean.  When I hooked up to the main harness and set the ignition to position 1, I am only getting Hi/Lo and Left/Right signals.  The horn was not working and I was not getting power through to the Brn/Wh wire for the tail light and the speedo and tach lights.
I have determined through testing my ignition switch is working properly.  Now that I have removed the left hand controls and have them on the bench, I am only getting continuity through the light blue- light blue/ wh for the right signal indicator.  Any thoughts are greatly appreciated.  This is the last thing on my check list before firing up and vacume synch.  Thanks
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
1995 Ducati 900 SS/SP
2000 Ducati 900i.e.
