Author Topic: 1971 750 K1 fork boots  (Read 608 times)
Offline jos1054
« on: February 20, 2013, 10:15:31 AM »
Hi all,
I'm new to the forum so I apologize in advance if this is a redundant topic. I've searched and go ogled but I just can't find the information I am looking for.
I am trying to install my fork boots.
Does anyone have an easy trick to install the upper collard to the boot?
Thanks
JOS
Offline cheftuskey121
  • Super Newbie
Re: 1971 750 K1 fork boots
« Reply #1 on: February 20, 2013, 06:38:52 PM »
what do you mean by fork boots? I may be having a brain fart here but I can't recollect the item you're talking about and I just did my forks
  • Super Newbie
« Reply #2 on: February 20, 2013, 06:39:57 PM »
ok brain fart for sure, fork gaitors. crap, I have not put those on. going to be in the same boat as you! good luck, I'll be watching this thread closely :D
Offline Prospect
« Reply #3 on: February 20, 2013, 07:32:02 PM »
Hi all,
Thanks
JOS
Are you talking about the chrome ring?  I had the same issue last summer.  Take a look at the link
http://forums.sohc4.net/index.php?topic=107986.msg1210172#msg1210172
http://forums.sohc4.net/index.php?topic=69807.0
If you're talking about the fork boots/gators onto the fork ear then it's just pure use of force to get it into place.  It took me a while.
« Last Edit: February 20, 2013, 07:34:47 PM by Prospect »
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline Johnie
« Reply #4 on: February 20, 2013, 08:34:31 PM »
Keep in mind there is a top and bottom to that gator. That lip on the inside of the gator top has to fit snug into the recess of the fork ear. Welcome to the forums. Click the pic to enlarge it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
« Reply #5 on: February 20, 2013, 09:27:15 PM »
Done this job 3 times and it was an arse of a job each time. BUT it was easiest for me the last time when I did a full bike rebuild - I mounted the gaitor onto the fork ear OFF the bike. Then I was able to fit the combined ear and gaitor on by sliding down the fork. Bottom of gaitor just prises over the fork - with some persuading with a flat but not sharp screwdriver.
Mark
« Reply #6 on: February 21, 2013, 03:48:01 AM »
And with all rubber bits, especially the old ones, a heat gun makes the rubber a lot easier to work with  ;)
