Author Topic: '78 CB750k conversion to cafe racer (yes, more issues)  (Read 64678 times)
Online Stev-o
Re: '78 CB750k conversion to cafe racer
« Reply #75 on: March 19, 2013, 06:02:44 AM »
What would you guys suggest?
Buy two new tires!  Doubt your front rim is an 18, check date of manufacture on the front tire, if over 6 years, time for new.
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
« Reply #76 on: March 19, 2013, 07:25:44 AM »
I was already going to get a Pirelli Demon for the front tire.. Rear tire is 4.25/85 H 18  which is bad news right? Tires aren't made in this dimension anymore if I read right.
I've read somewhere that Honda Man suggests a symmetrical blocked pattern for the rear tire for optimal performance.
« Last Edit: March 19, 2013, 04:34:35 PM by deafcaferacer »
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
« Reply #77 on: March 19, 2013, 04:36:38 PM »
120/90 x 18H = 4.25 x 18 correct?
Thinking of the Pirelli MT66 for the rear tire.. they have 120/90 x 18 and I've read good stuff about them. I'm already going with Pirelli MT66 for the front tire. Feedback would be appreciated
Online Stev-o
« Reply #78 on: March 19, 2013, 08:46:00 PM »
No, 120mm = 4.72", that is the width of a 120/90-18 tire.  OEM was 4" wide, but I run the 120.  Some guys will tell you that it will wear in abnormal way and cause handling woes.
My K4 is not a daily rider and will only see a couple thousand miles annually so not a concern to me.  Pirelli has a very good reputation but I've only had them on my Honda sports car not one of my bikes.
« Reply #79 on: March 20, 2013, 09:12:21 AM »
Would 110/90 or 110/80 be a better fit?
Online Stev-o
« Reply #80 on: March 20, 2013, 10:08:21 PM »
Would 110/90  be a better fit?
Yes, at least it would be closer to stock. 110 = 4.33"
« Reply #81 on: March 21, 2013, 07:22:14 AM »
Thanks.. I finally figured out that it's a straight up conversion rate.. e.g., 110 is 110mm, literally 4.33 inches.
I know that a lot of the questions I ask here are fairly basic, and if there were a beginner's section in this forum, I would ask my questions there to avoid cluttering up this project thread, so thanks for your patience.
That being said, is the aspect ratio important? I.e., 110/90 vs. 110/80?
Online Stev-o
« Reply #82 on: March 21, 2013, 07:34:28 AM »
You can always search the forum to basic questions but we are happy to help.
The /90 is the aspect ratio, the height of the tire from rim to top of tread will in this case be 90% of the width (110mm). On sports cars, we call it low profile when they have 50 or 60 series tires, very good for handling but can bring a harsh ride on bumps.
Personally, I always stick to /90 aspect ratio tires on my bikes. I did order a /80 once, did not like the look of it at all, diddnt mount it and returned it for a /90.  Do you have a local bike shop locally that you can go look at tires?
Here is more info to educate yourself, you probably didn't know that there was so much to buying a set of tires!
http://www.totalmotorcycle.com/photos/tire-tyre-guide/Tire-TyreTech.ht
« Reply #83 on: March 21, 2013, 08:35:45 PM »
Started reading through it. Looking through the tires types. I'll be mastering this stuff in about 5 years.  ::)
Question.. would 4.00 be okay? The tire I currently have is a 4.25, and the rim is 3 1/4"
« Reply #84 on: March 23, 2013, 08:19:12 AM »
Bike is in the shop today to have the hoop welded on. It was mocked and ended up being a little too long so we moved it up 3-4" barely enough for me (big frame) and a passenger.
I now have a 750k rear fender/brake light for sale if anyone wants it. Will be posting in the sales forum.
« Reply #85 on: March 27, 2013, 09:07:59 AM »
Well, it's one week later and the vinegar bath is ready to come out of the gas tank and boy did it vomit plenty of chunks of rust. I then hit it with a neutralizing bath of baking soda and 1 gallon of warm water, then sprayed with WD40 and sloshed it around for a bit, and voila!
I saw the perfect chain to use at Ace hardware, pointed edges and coated in zinc- it worked wonders. 3 feet for a total of $4.. the entire project, vinegar, baking soda, and WD40 set me back a whopping $25.
Offline Elan
    • Vital Motor Parts
« Reply #86 on: March 27, 2013, 09:10:29 AM »
phosphoric acid from lowes works great too
76 750k
Offline Bankerdanny
  • Endeavor to persevere
« Reply #87 on: March 27, 2013, 09:41:13 AM »
I'm sure they aid slightly in cooling but most of us have put them on purely because of looks
+1.   If you ride in MA, doubt you will have an issue with overheating.
Don't be too sure. Boston traffic can suck as bad as Chicago traffic I'm sure, and an 80+ degree summer day combined with gridlock does not equal a happy air cooled motor.
« Reply #88 on: March 29, 2013, 03:45:18 PM »
Seat pan fabbing is done! Going to send it out to be padded soon. It looks and is long (27") but fits me because I have a tall frame (6'4) and leaves just enough room for one petite and cute passenger  :P
Offline Elan
    • Vital Motor Parts
« Reply #89 on: March 29, 2013, 07:54:59 PM »
Have you found a local place to upholster it? Im working on a cb450 for a buddy who wants to reupholster his seat...
76 750k
« Reply #90 on: March 30, 2013, 09:21:13 AM »
Elan, there's a guy up in New Hampshire who's supposed to be good, but he hasn't answered my email yet. Will let you know who I go with.
« Reply #91 on: April 01, 2013, 09:51:12 AM »
Scored a nice set of used turn signals off ebay and ordered new lens because I anticipated old lens was cracked, but when I removed old lens, I found the turn signal gaskets to be thoroughly rotten. Back to ebay to order new gaskets.  >:(
Offline knowsnothing
« Reply #92 on: April 01, 2013, 11:34:14 AM »
Hey guys, I have a buddy down on the south shore that does upholstery.  Its his side business and he usually does hot rods, but i already talked to him and his is down with motorcycle seats.  If you are interested pm and I will send you his information.
1978 CB750k Blue - for sale
« Reply #93 on: April 01, 2013, 12:06:47 PM »
PM sent, thanks.
« Reply #94 on: April 05, 2013, 10:37:11 AM »
Brake light mounted. Things are really coming together. Only thing left is to get the wire harness, and get the seat pan upholstered.
« Reply #95 on: April 27, 2013, 06:04:14 AM »
Just got my bike back from the mechanic after some wiring issues, fired it up and took it for a ride and had a religious experience. Really love the bike even if there's much more to be done. Will try to post pics as soon as  some more kinks are worked out.
Online Stev-o
« Reply #96 on: April 27, 2013, 06:25:22 AM »
Ha! been there. Glad to hear it's running.   Have you given it a full tuneup and carb rebuild?
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #97 on: April 27, 2013, 06:39:29 AM »
You fello Mass dudes. I have seen work by a guy in Foxboro that is really nice. Mikes Uphostery ? I think it is. On rt140 .
« Reply #98 on: April 27, 2013, 08:57:20 AM »
Don't know of him. I sent you a PM about AM side covers.
« Reply #99 on: April 27, 2013, 08:59:17 AM »
Here is where the bike is at this point. Still have yet to get the seat back, and the left side mirror isn't holding- the flare up ring isn't big enough to grab on so I am looking for another one with bigger flange, and failing that, will have a nut welded inside the handlebar.
