Author Topic: Head advice needed  (Read 657 times)
Head advice needed
« on: February 25, 2013, 04:50:29 AM »
So I took of springs from the head - 1978 CB750F.  Here is what I found:
1. Leak test was good, no leaks whatsaver.
2. Valves have some play, sttill need to check it against HM book specs.
3. All intake valves are mushroomed to some extent, I was not able to pull them out by hand.
4. #2 intake is the worst, #4 is second worst.
5. The cam is looking good, same for arms.
See pictures for details - the #2 indent is 0.8mm deep.
And my questions are:
1. Why is there the indent?
2. Is it ok to grind it off and reuse the valve?
3. How to prevent it from happening again?
4. Should I replace tappet screws?
5. Should I replace valve guides anyway since it is F and guides will go bad no matter what?
Any insight is highly appreciated.
Re: Head advice needed
« Reply #1 on: February 25, 2013, 09:35:11 AM »
Anyone?
« Reply #2 on: February 25, 2013, 11:55:02 AM »
Hmm, looks like somebody here had similar problem:
http://forums.sohc4.net/index.php?topic=82431.0
Offline Vinhead1957
« Reply #3 on: February 25, 2013, 12:43:35 PM »
I don't think that valve would pass specs.   Valves are measured for trueness as well as length and diameter.  Valves are pretty hard that is peculiar damage.  How is the piston top?
