Author Topic: carb rebuild kits for 76 cb550 ...where can i find them  (Read 3340 times)
Offline blfellers
« on: February 25, 2013, 08:56:45 PM »
76 honda cb550f super sport...where can i find a rebuild kit for these carbs and how can i tell what kind of carbs i have and are they k or f carbs?....plz help!!!
Offline goldarrow
  • one day, i'll be an
Re: carb rebuild kits for 76 cb550 ...where can i find them
« Reply #1 on: February 25, 2013, 09:29:42 PM »
I think your carb is 069A but I could be wrong though. Check against the manual.  Also look for stamp on the right hand side of the carbs bracket.
Get carb rubber oring kits from your local Honda dealer.  Reuse and clean all brass parts really well. Search the forum on how to install/reinstall carb bowls gasket technique as you're more likely have to it this more than once.
CB550 K0
Offline harisuluv
« Reply #2 on: February 25, 2013, 10:28:41 PM »
Numbers on the carbs won't matter if you are going for the OEM gasket kits and reusing the brass bits. Honda kits are the best quality but their gasket kits are just top cover and bowl gaskets and some o rings. Should work on any cb500 or cb550 non pd style.
Many members get parts from partsnmore.com they do sell full rebuild kits. I think they are ok but it is thought that the needles are quite inferior to used OEM.  Hopefully you are pointed in the right direction.
« Last Edit: February 25, 2013, 10:31:03 PM by harisuluv »
« Reply #3 on: February 25, 2013, 10:45:46 PM »
Also siriusonic in canada(not sure of spelling)
Offline 2ceebees
« Reply #4 on: February 26, 2013, 09:23:48 AM »
Got nice rebuild kits for my 75 CB550 from DimeCityCycles.
1975 CB550K1
and other bikes..
Offline blfellers
« Reply #5 on: February 26, 2013, 09:43:29 AM »
thanks guys i really appreciate it! Now the next question is where can i get and what kind of carb solvent should i use to cleam them because they are NASTY again thank you all for the replies back
Offline 2ceebees
« Reply #6 on: February 26, 2013, 10:06:11 AM »
I use Berrymans carb cleaner.  1 gal can avail at Autozone, Checker Auto, etc.
1975 CB550K1
and other bikes..
Offline blfellers
« Reply #7 on: February 26, 2013, 10:20:03 AM »
do you just set the carbs in the cleaner and let it soak overnite or what?
Offline 2ceebees
« Reply #8 on: February 26, 2013, 10:29:12 AM »
Basically yes, depending on how bad they are.  I strip the carb down first.  Let it soak for about two hours first and check it afterwards to see how it's doing.  I've left really nasty carbs soaking overnight but only about 6-7 hours.  Too long and it can oxidize the alum a bit.
1975 CB550K1
and other bikes..
Offline Bankerdanny
  • Endeavor to persevere
« Reply #9 on: February 26, 2013, 01:45:10 PM »
There is another downside in soaking overnight, some of the shafts that run through the carbs are sealsed with felt washers and carb soaks like the Berryman's can ruin those and cause sealing issues.
Offline blfellers
« Reply #10 on: February 26, 2013, 04:51:11 PM »
so i started to tear into these carbs and i cant even pull the ploat pins out and the one pin i did get out i broke the little "tab" thing that holds the pin in...is there any way of fixing this... maybe use jb weld or something cuz i dont want to have to but a new carb and ill tell yall these things are super gummed up i have never seen carbs this bad...any other advise would really help.  THANKS GUYS
Offline goldarrow
« Reply #11 on: February 26, 2013, 04:53:12 PM »
Big Ouch!  I think you be better off buying a new individual carb or a whole set
CB550 K0
Offline blfellers
« Reply #12 on: February 26, 2013, 05:17:20 PM »
ya thats kinda what i thought..are there any sites on the internet that sell used carbs that are still in pretty good shape?  i have been looking but cant really find any sites
Offline 2ceebees
« Reply #13 on: February 26, 2013, 05:29:53 PM »
Ebay
1975 CB550K1
and other bikes..
Offline blfellers
« Reply #14 on: February 26, 2013, 05:50:57 PM »
well i just ordered the inside left body (the side i broke)..cost me 12 dollars for it not bad ..now is that on the riders left..i just wanna make sure
Offline goldarrow
« Reply #15 on: February 26, 2013, 05:59:01 PM »
Now is the time to make sure you know your carbs model number.
CB550 K0
Offline blfellers
« Reply #16 on: February 26, 2013, 06:03:36 PM »
the carb number is 069a..is there a difference in the 76 cb550f carb bodies?
Offline goldarrow
« Reply #17 on: February 27, 2013, 09:01:27 AM »
From what I have read, no difference in the carb body, but jet sizes
CB550 K0
Offline Deltarider
« Reply #18 on: February 27, 2013, 10:03:16 AM »
Where did you read there is difference in jet sizes?
CB500K2-ED Excel black
Offline goldarrow
« Reply #19 on: February 27, 2013, 10:57:03 AM »
All over the forums? Some said 38, some said 40 for the mains.  May be the air/fuel screw turns out that I was referring to? But I always go by what the manual said.
CB550 K0
Offline Deltarider
« Reply #20 on: February 27, 2013, 12:28:39 PM »
069A Carbs (550F models) all have #38 slow and #98 main jets.
It could be that Honda has sneeked in some changes in settings in the F2 as it had to satisfy emission rules, but I don't think the sizes were changed.
« Last Edit: February 27, 2013, 12:30:17 PM by Deltarider »
