Author Topic: Sandcast 4286 Project  (Read 161735 times)
Re: Sandcast 4286 Project
« Reply #725 on: December 27, 2014, 03:55:38 PM »
Glad you found the issue, Greggo.  When will you slap the motor back in?
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #726 on: December 27, 2014, 06:28:33 PM »
Next week I hope!  I left the top end disassembled so I can go back at it with fresh eyes to search for metal shavings, so I still have all that work to do, then getting it back in the frame is always fun, right!? :P
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #727 on: December 27, 2014, 08:02:32 PM »
bunnava#$%*ch!   >:( glad things didnt turn out worse!
Offline markb
  • When I finish my current project I might be a
« Reply #728 on: December 28, 2014, 07:25:07 AM »
I'm happy to see you found the problem too.  I know the feeling but the extra effort will be worth it for peace of mind.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
« Reply #729 on: December 28, 2014, 08:47:19 AM »
Be sure to use thread sealer on the 4 front stud holes, which are through holes to the atmosphere.
Offline Greggo
  • Somebody's
« Reply #730 on: December 28, 2014, 08:51:57 AM »
Thanks guys, I'm cautiously optimistic.  I have more time and money into this bike than anything else I've done in life besides college.  I'm ready to put some miles on this one already, and I haven't had a good ride since I sold the '71 500/4...I miss that bike :-\
Thanks for the heads up MC..I will seal those studs.  I'm also pulling the old/new/used/leakingAfter10miles pucks to replace with new ones and fresh non-hardening sealant.
« Reply #731 on: December 28, 2014, 09:09:22 AM »
Great. Those 12 holes are problematic on heads that have been worked on, the 4 in front particularly.
I was educated on the pucks as follows (from discussions here): Some aftermarket pucks are not thick enough to do the job properly. Pays to use OEM or check the thickness of new aftermarket to see that they comply. You'll have to search for what that thickness really is, I don't have it handy.
Certainly, if you drop the puck into a clean hole it should stand proud of the hole, so that it wil squish when the cam bearing is dropped on. Use a short straight edge to test it.
(All my comments above are from first hand experience)  :D
  • Gusto mo titi ko?
    • project
« Reply #732 on: December 28, 2014, 09:16:05 AM »
i concur, experience cannot be easily taught
Offline Greggo
  • Somebody's
« Reply #733 on: December 28, 2014, 11:21:53 AM »
This head came from Bill Benton, and had aftermarket springs and keepers...it had definitely been worked on ;)
All six pucks stood proud of the head upon inspection, but the threads were unable to hold enough torque to seal the sandwich, especially right above the leaky puck where I could rock the 'tightened' bolt back and forth after removing the valve cover.  I'm replacing them with new Yamiya pucks as cheap insurance.
« Reply #734 on: December 28, 2014, 11:25:04 AM »
Sounds good.  :D
Offline Greggo
  • Somebody's
« Reply #735 on: December 28, 2014, 11:27:12 AM »
I appreciate all the help and motivation guys, this is why I keep coming back here!
« Reply #736 on: December 28, 2014, 04:03:17 PM »
We wanna see this one back on the road!
Offline Greggo
  • Somebody's
« Reply #737 on: December 28, 2014, 11:17:11 PM »
I hope you get that pretty H1 back on the road soon too, Stev-o!
« Reply #738 on: December 29, 2014, 05:55:45 AM »
I've decided to do a full rebuild on the motor so it will be a couple months.
Offline Greggo
  • Somebody's
« Reply #739 on: December 30, 2014, 02:50:19 PM »
I only had a little bit of time today.  I gave the head one last cleaning, then blew everything out with compressed air, and scanned it again for metal shavings and flakes.  The four head studs got their blue thread locker, all the head bolts were re-torqued, and the cam is back in.  The next step will be setting the timing.
« Last Edit: December 31, 2014, 09:12:29 AM by Greggo »
Offline Greggo
  • Somebody's
« Reply #740 on: January 02, 2015, 03:12:08 PM »
Buttoned up with the valves adjusted.  I have to wait until next week when I can get some help lifting it and getting it back in the frame.
Sure felt nice properly torquing all twelve of those bolts!
« Reply #741 on: January 02, 2015, 04:33:01 PM »
And looks good too.
Offline Prospect
« Reply #742 on: January 02, 2015, 06:43:28 PM »
I had to heli coil nine of the twelve cam tower threads when I tore my k1 apart.  I couldn't torque them down to spec otherwise.  Great work Greggo!
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline David B
« Reply #743 on: January 03, 2015, 07:18:37 AM »
I really respect your thoroughness and dedication to having it 100% the way you want it. Very admirable!
DB
Offline Greggo
  • Somebody's
« Reply #744 on: January 09, 2015, 10:53:39 PM »
Seems like every damn thread wants to strip on this motor :o
#4's outside exhaust spigot screw got cross-threaded and I had to helicoil it.  I'm lucky to work in a shop where there just happened to be M8x1.25 helicoils and the 21/64 drill bit sitting around...I'm farking superman at this point feeling like nothing can stop me after fixing that..then when I was clamping down the last of the four oil hose to engine bolts down by the brake pedal that bastard decides to strip!  It was a short bolt, and I had a spare '8' head just about 5mm longer, which grabbed enough threads to torque properly  8) 8)
So, I've got the whole bike back together oiled up but no gas because I ran out of time.  Next week if no gas leaks I'll put some miles down.
I forgot to take a pic after putting the pipes back on it.
Oh, and here's the 23-window + sunroof van the shop bought yesterday.  The bear came with it, and stays with it.  ;D ;D ;D ;D
« Last Edit: January 09, 2015, 10:55:21 PM by Greggo »
Offline Trad
« Reply #745 on: January 09, 2015, 11:01:45 PM »
Looks great!
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
« Reply #746 on: January 09, 2015, 11:27:17 PM »
Greggo,
Let us know when you manage to fire the bike.
Don
« Reply #747 on: January 10, 2015, 07:11:44 AM »
Alright Superman, were rootin for ya!
Those VW's sell for big bucks when restored, I don't get it, but I've never been a VW guy.
Offline toytuff
  • "watching the pinheads"
« Reply #748 on: January 10, 2015, 07:18:12 AM »
HA! And you think the Honda was a project?  :o
Nice bus.
tt
Offline Greggo
  • Somebody's
« Reply #749 on: January 10, 2015, 09:35:04 AM »
It's a numbers thing with these buses.  So many regular buses made, but not so many of these, which are even rarer than the 21-window version without the back corner windows.  And as time went on most of them crumbled away from rust, or got crushed because nobody cared for decades. This one is really nice as far as a starting point.  It's solid, and not very rusty.
