Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
.Heavy duty nuts may not be nessesary, but they sure make me feel better , been using 1600 air cooled vw nuts an washers for yr's ,no problem, 15mm head ,larger thicker washer , stock ones not hardened ,but c/moly nuts n washers are available ,claerancing round cam cradles on some heads
Quote from: sohc boy on March 10, 2013, 03:20:43 PM.Heavy duty nuts may not be nessesary, but they sure make me feel better , been using 1600 air cooled vw nuts an washers for yr's ,no problem, 15mm head ,larger thicker washer , stock ones not hardened ,but c/moly nuts n washers are available ,claerancing round cam cradles on some heads Can i ask where did you bought your VW head nuts and washers?Bert....i also dont want to step on Jay's towes , can get from any vw mechanic , dismantler , they are later 1600 thin stud model....75 76 ,
They are completely ''nuts'' they ask 28.25$ just for the shipping!!!!Bert
VW Aircooled engines didn't come with flanged head nuts that i know of . They used nuts and washers. 2 different sizes through the years....10mm studs on early engines and 8mm studs on the later engines. Here is some nuts on ebay........ http://www.ebay.com/itm/VW-Beetle-Cylinder-Head-Hex-Nut-8mm-kit-16-for-Air-Cooled-Engines-98-0144-B-/330864108392?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d0909a368&vxp=mtr
