Author Topic: my 77 5507 keeps blowing the main fuse  (Read 457 times)
Offline klinger44
« on: March 10, 2013, 05:00:46 PM »
Basically my 550 keeps blowing the main fuse and sometimes melting it. It blew 5 times today alone on a 60 mile ride. Ive checked all the wiring amped out while idling and at highway rpms and nothing. It only blows when i am almost at a complete stop it blows , it is hot and i know the theory that it could be the fuse clamps and thats why th fuse is hot as #$%* when i pull it out but any fuse running at its amp limit for an extended period of time will heat up the fuse. Not that the loose or corroded clamps wouldnt do this but so can any hi resistive short. IF the fuse for some reason is pulling 14 amps for an hr and then hits 15 the fuse would be hot. I havnt seen with my amp prob it go over 9 amps though. Any other thoughts. Also i have a new battery but the bike sometimes will button start and sometimes the battery is dead. If i ride it for and hr and then turn it off i can button start it but if i wait more than a few mins it wont and ill have to kick it. Not sure if this could be related but when the fuse isnt blowing the bike runs like a dream , it kicks starts the first time every time. I put brand new carbs on it. my fuse clamps seem tight and i have already cleaned them and it still blew 5 times today, the most times its ever done it before is like once or twice a month
Offline davesee
Re: my 77 5507 keeps blowing the main fuse
« Reply #1 on: March 10, 2013, 05:06:37 PM »
cool bike.
it sounds like short somewhere. check your batter terminals and cables and make sure they aren't contacting the frame. if the short is in the harness, it's going to tricky to find...i ounce found mine by listening to it sizzle after a rain storm, and it was deep in the harness.
good luck.
1980 honda cb650 with many weekends worth of modifications.
Offline klinger44
« Reply #2 on: March 10, 2013, 05:26:08 PM »
thanks , the bike hasnt been in the rain or even wet in the year i owned it. but its done this pretty often since i got it
bollingball
« Reply #3 on: March 11, 2013, 09:35:59 PM »
I don't think he meant the rain caused it. It just made it easy to find. Sounds like a momentary short. Might be better to check resistance and wiggle the wires before you have a fire. This would be a good time to clean all your connections while looking. Take a few things off and look at the back like the fuse block.
                                                     Ken
