The first couple of things I would suspect without actually looking at it are the ignition advance unit and the condensers. They both come into play around the 3000rpm mark. The advance mechanism is a mechanical type and is behind the points plate, it has a tendancy to become stuck, it just needs to be pulled apart, cleaned and lubed.
