bollingball: Here is a side profile pick of filter on bike so you can see size if that is what you are asking. The first pick is with a stock air box and the second is with the new air filter. I am using "K" side covers on this "F" bike. The air box was for an "F" and I think that's why everything didn't line up or look right. You can see in the first pic when you mix and match components things start looking odd!
lucky: I'm already on top of the "set screws". They give you some short ones and I went to Lowe's and got a little longer (I got gorilla hands/fingers). There are three set screws on each (12 total) holding filter on, so I only set them just until they made contact and then ever so lightly gave a little more.
Stilltime: As for up date. On there site they didn't post that they had these. I contacted them because I had a question on something else I was working on and I had seen some one that posted they had gotten there two peace bread box filters. He told me he had this one (single, rounded end bread box style) and would I be interested. If you are interested in this style just contact Steel Dragon and talk with them. If you have to use me and these pictures for reference. They are members of this forum.
As for an update on performance, they are working out great. Here is a break down on what I have and done:
Bike is a stock 78 CB750F (no performance mods). From what I've read "F" bikes ran somewhat lean from factory.
Carbs are from a 77 CB750K.
Exhaust are Mac 4 into 2 turnouts with baffles (they were also for a "K" model)
Also have Dyna S ignition and coils.
As for the carbs the 77 "K" had stock: 115 mains, 35 slow and adjustable needle (on first/top notch clip)
For a stock 77/78 "F" motor and carbs it should run 105 mains, 35 slow and non adjustable needle (set at what would be first/top notch clip)
Because I went with the air filter and Mac exhaust I put in: 120 mains, 42 slow and adjusted needle to second from top notch clip (raised needle up one notch from stock position).
I also blocked off the upper half of the air filter for two reasons: 1. reduce air intake just a little 2. keep water out in event of riding in rain or cross wind issues. I read that pods and these bread box type filters can perform better with these simple mods.
Post is a little long, but hope it answers some questions for anyone interested.
dlhoulton
