Author Topic: Honda factory fork seals, Which side is up??  (Read 823 times)
Offline tmac
« on: March 13, 2013, 11:54:51 AM »
Guys any help would be graciously accepted. All ready to reassemble my forks with all new parts & Im not sure which way the fork seals go in. If it helps one side has a wider groove than the other. Also ATF or Fork oil guys??  Thank You Kindly !! Tim
Re: Honda factory fork seals, Which side is up??
« Reply #1 on: March 13, 2013, 12:57:17 PM »
The scraper lips point down.Post a picture if needed and someone can tell you if it correct as it sits or needs to be flipped. Does one side have any writing. ?
Offline Johnie
« Reply #2 on: March 13, 2013, 12:59:57 PM »
On the OEM seals the writing side goes up...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline tmac
« Reply #3 on: March 13, 2013, 01:11:18 PM »
writing side up, Thanks very much !!!! :D
Offline Pat_at_APE
    • APE Race Parts
« Reply #4 on: March 13, 2013, 02:08:05 PM »
I used ATF and I like how it rides.
Pat at APE
Offline Johnie
« Reply #5 on: March 13, 2013, 02:52:16 PM »
I went with 10w fork oil. Depends on how stiff you want the ride too.
Oshkosh, WI  USA
« Reply #6 on: March 13, 2013, 03:38:22 PM »
One other little trick if your old springs are a little sacked is to put some large washers or other suitable filler pieces under the fork caps on top of the springs to add a little extra preload.
