Sadly, the situation we face today is due to the introduction of [only] non-leaded fuels AFTER these bikes were out there, beginning in 1984. The guides in particular suffer from it, as they were designed to be used with leaded fuels, which specifically lube the guides and top ring on the piston(s). So, after the engines were broken in with the 'right stuff', the 'stuff' disappeared and the wear cycles increased a lot.
I started using top oil in [almost] every fillup, and after 140k miles my guides are just approaching a worn state, not at max yet. And, it doesn't burn oil yet, either. But, the 750K0-K3/500-4 and 550k1-3 had the Stellite guides, which fare much better than the later cast iron types. Starting in 1976, all of the guides are cast iron, and during the years of MTBE additive in our gas, these guides were eaten by the acidity of that additive. I haven't seen a 650-4 or 550F head since 2000 with good guides in the exhaust side, and most of the 750F bikes are in the same boat.
Modern bronze guides will help a lot, and I've also worked out a way for a local machine shop to install bronze liners instead on the bigger 750 heads.
This is, if I can get my turn 'in line' in less than 10 weeks to get the heads actually done...
