Author Topic: Oil blowout all over rear tire, swingarm etc. 750K3  (Read 6266 times)
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Oil blowout all over rear tire, swingarm etc. 750K3
« Reply #25 on: March 20, 2013, 09:09:52 AM »
Could be a possibility but I doubt it.
As I said in post #5 I check the oil fairly religiously on this bike a few minutes after I ride when I get home.
« Reply #26 on: April 15, 2013, 07:32:19 PM »
**Update**
Ok, after pulling the battery holder and loosening the oil tank and disconnecting all the electronics from the harness I got to the suspect breather tube when I pulled it it had a tear/cut on the bottom side but it did not appear too big, maybe 2 or 3 mm in length but it looked like it could leak oil potentially. I replaced it with the hose I got that I described before but have yet to test out if that tube was the problem or not. We'll see.
« Reply #27 on: April 21, 2013, 01:02:35 PM »
Looks like it was the breather tube leaking after taking a decent ride yesterday on the highway and streets.
No leaking on the top of the swingarm like before so I will take that as the root cause for a decent amount of the leakage.
Now I just need to plug up the chain oiler leaking and that should take care of most of the rear leakage.
Offline Henning
« Reply #28 on: April 22, 2013, 08:16:00 AM »
Here's hoping the problem is solved, but be careful. These bikes are known to barf lots of oil out of the breather pipe on the top of the oil tank. Scary; it all ends up on your rear wheel. I have yet to see an explanation or solution for this.
71 or thereabouts 750 K1 - this one should have been put down
