Author Topic: CB400F "Replacement Girlfriend""  (Read 18432 times)
Offline SONIC
    • Walnut Wood Works
Re: CB400F "Replacement Girlfriend""
« Reply #50 on: April 10, 2013, 07:03:27 PM »
Thanks!
Anyone in the area (or not?) is welcome to come hang out in the shop  8)
Ill have a look tomorrow I cant remember off the top of my head    ???
So after 30 miles or so the oil pressure light has started staying on.
When i start the bike it goes off like it should, and it will stay off while idling. Once I hit the road about 2 minutes into riding the light comes on and stays on until I turn the bike off and start it again...
What are the thoughts here?
Faulty pressure sensor?
Low oil pressure? (no leaks)
Etc?
Offline Powderman
« Reply #51 on: April 10, 2013, 07:43:08 PM »
I wouldn't put any more mileage on the bike til you diagnose the issue. I'd hate for you to find out the hard way that that light was working correctly.
« Reply #52 on: April 11, 2013, 04:48:16 AM »
Most likely is the switch, but agree with Powder, you need to confirm.
Look here for a couple things to check...
http://forums.sohc4.net/index.php?topic=50471.0
Offline SONIC
    • Walnut Wood Works
« Reply #53 on: April 17, 2013, 07:38:35 AM »
Confirmed oil pressure is just fine if not a little high
ANd took her on a shake down run!
nearly 100 miles on her now and she's running like a top.
I got incredibly angry and hostile with the stock air plenum, eventually throwing it across the shop and putting on pods. It runs like a dream with the cheap emgo pods that I didn't want to use. Guess ill get some K&N's and she'll really be running well.
Next up hopefully this week is get the seat done so I dont end up with more bruises on my ass. 100 miles on a metal seat pan is a painful experience.
Offline iron_worker
« Reply #54 on: April 17, 2013, 08:17:27 AM »
You're a tough sunuvabeech to be riding on that seat at all! lol
IW
Offline Vinhead1957
« Reply #55 on: April 17, 2013, 12:39:52 PM »
Looks great!
Offline SONIC
    • Walnut Wood Works
« Reply #56 on: April 17, 2013, 06:12:18 PM »
Thanks guys!
Left side cover flew off somewhere on the road today....
anybody have one sitting around they would be willing to part with?
Or know of any cross compatible covers?
« Reply #57 on: April 17, 2013, 10:11:54 PM »
I have a couple 400 side covers, not sure what side. Will grab em out of my storage next time I am there.
Send me a PM as a reminder.
And plz tell us you plan to put a pad on that seat!
Offline SONIC
    • Walnut Wood Works
« Reply #58 on: April 18, 2013, 09:57:53 AM »
Steve-o you're the man my friend.
The seat pan will hopefully get finished tonight and then upholstered early next week.
« Reply #59 on: April 18, 2013, 09:18:02 PM »
PM sent....
Offline SONIC
    • Walnut Wood Works
« Reply #60 on: April 28, 2013, 11:26:20 AM »
Paypalled steve, covers on its way.
Seats at the upholsterer, hopefully get it back on monday.
Tail lights/brake lights are all wired up using 2 SPDT relays. Blinkers only work when the brake lights are on however, so I may have to figure that out, although I dont see the need to use them when im not on the brakes anyway?
Any ideas here?
The brake lights are connected to the normally closed part of the relay so when i hit the brakes the lights come on, then the coil is connected to the blinker circuit, to it disconnects the NC and goes to the NO position, effectively cutting out the brake light and blinking like a blinker.
Just realized maybe I can do a similar wiring setup with the running lights to have blinkers all the time!
Maybe Ill go play with that now.....
Also, does anyone have a picture of a bikini or 1/4 fairing or flyscreen on a 400f?
I cant find any, but I think my bike is asking me for one.
Offline SONIC
    • Walnut Wood Works
« Reply #61 on: April 28, 2013, 01:53:20 PM »
So heres my wiring setup for the running/brake/blinkers:
The Top Led's are running lights (they are actually in the same housing on the bike)
The flasher basically causes the relay to switch from the NC position to the NO position, causing the brake light on that side to cut out at 1hz. (effectively acting as a blinker)
SO my question is this:
Does anyone see a way to make the running lights blink with the flasher as well? At present the blinkers only work when i'm on the brakes which isnt a huge issue, but it would be nice to have them working all the time.
Offline SONIC
    • Walnut Wood Works
« Reply #62 on: May 04, 2013, 06:29:16 PM »
FInally got my seat back!
He did a good job even if he's kind of an #$%*.
It came out pretty much exactly how I wanted. I would have liked a little lower profile I think but hey it's more comfy for my ass this way. I'm very please with the look.
The side covers will probably get a quick rattle can job black for this season and then she will be done until winter!
Offline Islandstar
« Reply #63 on: May 05, 2013, 06:02:34 AM »
ANd added a rear hoop to the frame
Slowly getting things done..
got the hoop welded on tonight, sorry no cool pictures this time haha the bike was all covered up with blankets
but heres the hoop welded up
I wanted it short, I think i left just enough room for a skinny girl on the back  8)
Nice build...i have the same bike but have never seen myself on it, how tall are you?
Offline SONIC
    • Walnut Wood Works
« Reply #64 on: May 05, 2013, 06:31:50 AM »
Thanks man.
I'm right at 6'
That's why I have that picture I was in the same boat!
Offline Islandstar
« Reply #65 on: May 05, 2013, 06:50:36 AM »
Thanks. Im 6ft 1, so think i should be ok. I've bee trying to decide if to keep mine stock, but I like where you're going, so think I'm inspired. I just need to figure out those handlebar risers.
Offline SONIC
    • Walnut Wood Works
« Reply #66 on: May 05, 2013, 07:35:40 AM »
I'm really digging the stock mod thing I did on this one. It's basically stock with a few cosmetic and performance mods.
I like to think of it as stock 2.0 or improved stock haha
Offline MotorFist
    • MotorFist
« Reply #67 on: May 05, 2013, 08:20:57 AM »
Your seat turned out great man. Bikes looking sweet!
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline SONIC
    • Walnut Wood Works
« Reply #68 on: May 06, 2013, 05:40:03 PM »
Thanks man I appreciate it!
So I'm having a little jetting issue:
When going quickly to WOT the bike stumbles badly.
Here's a video with no load
Just noticed It does it at idle with no load too.
Basically wot = dead bike:
I know the 400f has no accelerator pump so it's gonna lean stumble a bit but this seems excessive. It also gets surgy and #$%*ty overall at high rpm.
I have a kerker exhaust, and pod filters.
Running an 80 main, thinking of going to. 85-90? Thoughts?
40 pilot. But it idles well, had some lean decel popping, but I richened up the idle screws but I haven't been able to ride I yet. Just from playing in the shop it seems better.
So what are you guys thoughts?
« Reply #69 on: May 06, 2013, 05:44:02 PM »
order a jet kit
Offline JimJamerino
  • Yay! I'm a
  • Not rich enough to be "eccentric."
    • My CB650C build thread
« Reply #70 on: May 08, 2013, 09:39:54 AM »
The way your diagram shows, your blinker circuit doesn't get power unless your brake is applied.  You need 12v going into the blinkers independently of the brake circuit.
~ Jim
formerly "emperorspartacus"
There are old bikers.  There are dumb bikers.  There are no old, dumb bikers.
My CB650C rebuild http://forums.sohc4.net/index.php?topic=74212.0
Offline iron_worker
« Reply #71 on: May 08, 2013, 03:12:42 PM »
Since these carbs don't have an accelerator pump they rely on being over-rich on the pilot circuit to be able to sustain a quick rev. Sounds like you need to possibly go to the next step up on your idle.
Changing your main jet won't affect how you are able to "blip" the throttle from idle or even from mid range.
IW
Offline SONIC
    • Walnut Wood Works
« Reply #72 on: May 08, 2013, 06:21:49 PM »
I did what 1000 people told me not to and bought a micro drill set and drilled an oil pair of jets out to .889mm or 88.9 (jet size)
Completely.
Different.
Bike.
Id say I was running incredibly lean up top, so much so that it was only firing every other rev or only running on a few cylinders. Because with the bigger mains in the thing scoots!
Everyone said i needed 80's but it turns out that a 90 is more in the ball park.
Now when my K&N's get here I can start doing plug chops to get it perfect.
Really psyched.
The roads are very wet, when I pulled out of my driveway I gunned it like normal and about lost it when I got wheelspin when I hit 7K in first haha.
Offline thestratomaster
« Reply #73 on: May 08, 2013, 09:36:59 PM »
Completely.
Different.
Bike.
Really psyched.
did the new jets fix the WOT bogging issue? I'm experiencing the same thing
Offline SONIC
    • Walnut Wood Works
« Reply #74 on: May 08, 2013, 09:38:55 PM »
Yeah they did as far as I can tell. Ill know for certain tomorrow
