Are the plug wires crimped on at the coil end? The OEM coil on my 750K2 has one wire that seems loose. I can tug on all the wires and they seem firm, but there is one that will twist freely right at the coil as if it is not completely connected. Its almost
like the other 3 are being held by both the conductor and the outside insulation, but the one in question is only being held in by
the conductor allowing it to twist where it goes into the coil. Are there known problems with the wires coming loose from the coil??
