Author Topic: New sohc4 owner here with a problem!  (Read 779 times)
Offline Yert315
« on: March 16, 2013, 07:36:59 PM »
Hey there fellas,
Just picked up a 1972 cb500 with a 550 engine. It runs, but needs a full tune-up so I decided to get started on it today with a valve adjustment and cam chain adjustment. .02" intake and .03" exhaust. Everything went well other than the #1 intake was not adjusting properly. I took out the bolt/nut to see what was going on and found it had been chewed up pretty good. I attached a picture to show the damage. The valve stem looks to be "okay".  I couldn't get a good picture of it, but the top (where the adjustment bolt is supposed to hit) looks fairly flat. There does look to be some wear on the side/corner of the stem, but again I couldn't quite see the entire thing with the rocker sitting there.
I have read about rocker shaft drifting causing this. However, if this were the case would it effect more than just one rocker? Should I be okay if I were to replace the adjustment bolt with a new one?
Any insight is appreciated.
-Trey
Re: New sohc4 owner here with a problem!
« Reply #1 on: March 16, 2013, 08:27:44 PM »
you can buy them new still,to check your rocker shaft wear in the housing remove those two end covers,then screw a 6mm bolt into the shaft thread and try to wobble it up and down and round and round,do this with say #1 on compression and the tappets backed right out,then with #4 on compression with its tappets backed out,you dont want any pressure on the shaft to test it.
Offline SohRon
« Reply #2 on: March 16, 2013, 08:28:12 PM »
Hopefully this is just a typo? S/B .002" & .003".
Offline Yert315
« Reply #3 on: March 16, 2013, 08:32:02 PM »
OK great will check that tomorrow. If there is play what will need to be done?
yes typo. They were .002 .003 gauges.
Offline goldarrow
  • one day, i'll be an
« Reply #4 on: March 16, 2013, 08:44:29 PM »
The play in the rocker shaft will shorten the camcover and camshaft life, and everything else that is associated with.
CB550 K0
« Reply #5 on: March 16, 2013, 08:50:59 PM »
youll have to replace the cover if its worn badly enough to detect movement,the later ones had a different shaft length that took the place of two shafts and was locked to the cover with a wedge type cotter bolt.
Offline Yert315
« Reply #6 on: March 16, 2013, 08:53:18 PM »
Great Thanks for the information!
