Author Topic: Building the Dream...  (Read 76600 times)
Online Stev-o
Re: Building the Dream...
« Reply #50 on: March 20, 2013, 07:09:49 AM »
Out of room? No way, I see room for at least three more in there!
Offline toytuff
  • "watching the pinheads"
« Reply #51 on: March 20, 2013, 07:26:55 AM »
 ;D
Time for a storage unit?  :D
I have to see if I can find some Barryman's carburetor cleaner. That slide is frozen. I think my only option is to cut the throttle cable.
Ordered all new cables anyway.
tt
Offline JimJamerino
  • Yay! I'm a
  • Not rich enough to be "eccentric."
    • My CB650C build thread
« Reply #52 on: March 20, 2013, 07:29:17 AM »
I have the same problem on my Dream- the carb slide is stuck solid.  It's a goofy design... you can't disconnect the throttle without opening the carb.  If you find a solution that doesn't involve chopping the cable, post it so my build this summer goes a little easier.
~ Jim
formerly "emperorspartacus"
There are old bikers.  There are dumb bikers.  There are no old, dumb bikers.
My CB650C rebuild http://forums.sohc4.net/index.php?topic=74212.0
Offline toytuff
« Reply #53 on: March 20, 2013, 07:33:19 AM »
Tim over a Classic Honda told me to soak it out of there if possible. You don't want to break the slide where the cable attaches.
Told me to buy some Barryman's carburetor cleaner. I'm spraying choke cleaner in there all morning.
Getting a good buzz on to!  :o
tt
« Reply #54 on: March 20, 2013, 07:45:19 AM »
Raise the roof and install 2nd floor motorcycle storage cubbyholes/racks  with hydraulic/forklift loading platform for easy access. Super insulated with heating and cooling system.
Yeah, that carb has seen some grime, crud, and gum.
How does the brakes look? At least you don't have white powder filled reservoirs...
What are you thinking about the spots that are worn through on the paint?
What protection coatings are there for use in battery area?
Time for some waxing yet?
How do you remove old tires without damage? (To replace/repair spokes)
Offline toytuff
« Reply #55 on: March 20, 2013, 09:21:07 AM »
David, you need to drink decaf!
tt
Offline toytuff
« Reply #56 on: March 20, 2013, 09:28:11 AM »
Quick trip to Walmart for some Berryman's carburetor cleaner.
Tip: Save those left over Mico dinner trays. Great for holding/organizing parts. The one being used has a strainer so the yuck can flow through.
First, I poured a little down the throat..
Then watched the nasty stuff drip..(photo reference)
Then used the top portion of the dinner tray so things would flow..
tt
« Reply #57 on: March 20, 2013, 09:30:47 AM »
Never have drank coffee, no mania here, just awake with  active imagination. & mind...
« Reply #58 on: March 20, 2013, 09:34:38 AM »
Got a soda blaster, homemade version or real deal? Blast exterior clean then Berryman's soak...
Offline toytuff
« Reply #59 on: March 20, 2013, 09:45:11 AM »
Nope, just a gonna soak. Have to keep an eye on it. Directions say no more than four hours.
I'm just trying to remove the slide. So far it's winning.
tt
Offline toytuff
« Reply #60 on: March 20, 2013, 02:00:18 PM »
I won round one!  :D This was about a two hour soak.
Loosing round two.  >:( The float bowl is fighting me now.
Done for the day. Very productive. Everything else around the house has gone to shid but progress on casper.  :P
tt
Offline JimJamerino
  • Yay! I'm a
« Reply #61 on: March 20, 2013, 02:02:37 PM »
Casper... heheh!  Maybe I should name my black Dream the Anti-Casper?   :)
Now that I think about it, I think I remember there's a pair of skateboard moves called the Casper and Anti-casper.  That wouldn't be sacrilege, would it?
Anyways, to stay on topic, I saw you cut your cable.  What's your source for new cables?  Would there be any way to maneuver the Berryman's can so you could salvage the cable?
« Last Edit: March 20, 2013, 02:04:59 PM by JimJamerino »
~ Jim
« Reply #62 on: March 20, 2013, 02:08:42 PM »
Everything else around the house has gone to shid but progress....
i know that feeling well.
carb looks like its got a new lease on life with that varnish gone  ;)
"This is my CB. There are many like it, but this one is mineā€¦"
Offline toytuff
« Reply #63 on: March 20, 2013, 02:09:38 PM »
Cables are cheap. I always replace mine. This one was not worth keeping as are the others.
http://www.classichondarestoration.com/index.php
Ask for Tim. Tell him John sent you.  ;)
tt
« Reply #64 on: March 20, 2013, 03:33:30 PM »
Throw the carb in a plastic ziploc and then in the freezer...  Thermal changes can sometimes help.
If you can get the right ends/fittings, then often new cables are the answer.
Unless the period correct nazis pick on your non-gray sleeved cables...
Does the CA77/CA78 have the sliding tab throttle arrangement?
You can get new grips that look like the originals that aren't rock hard, they are firm...
Carpal tunnel can be really aggravated by vibrations.  Tendonitis as well.
Dealing with numb fingers is OK, it is the pain that tendonitis brings that bothers me. Time to go take some B vitamins to see if that helps in a couple weeks...
Cajun tilapia baking in the oven should be done...time to go check it out...
David
Offline HondanutRider
« Reply #65 on: March 20, 2013, 04:04:18 PM »
Rather than soaking some gummed-up stuck carburetors, try a little heat.  A heat gun works good and even a hair dryer might be enough.  Spray some WD40 to help it along.  Those other strong chemicals can be nasty.
Offline toytuff
« Reply #66 on: March 20, 2013, 04:13:44 PM »
Teh chmicels didd nott effec me in zany wyy tht I can se.
tt
Offline Old Scrambler
« Reply #67 on: March 20, 2013, 04:23:15 PM »
Your doing just fine.........but Yamaha carb cleaner is the best.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #68 on: March 20, 2013, 04:24:42 PM »
Yeah but that Margarita might be affecting you...that agave nectar is building to high levels...  Need that warmth to continue to build to burn it out to normal levels...
Offline toytuff
« Reply #69 on: March 20, 2013, 04:30:29 PM »
Iff I livve therw that galln cam I hav noww I'll fly tht.
tTT
« Reply #70 on: March 20, 2013, 04:37:57 PM »
Can you still get the good Yamaha carb cleaner. I had read the new formula wasn't even half as good as the original, but stories do become yarns by many...
Offline Gregorymoto
  • SOHC Aficionado
« Reply #71 on: March 20, 2013, 04:41:46 PM »
Clean!!!
Very cool man.
Yep, i have issues with this sort of stuff.
Offline toytuff
« Reply #72 on: March 20, 2013, 04:45:38 PM »
Clean!!!
Very cool man.
Butt aht A cust
                        I thin mY vison is gettin g badd
ttttttttt
Offline toytuff
« Reply #73 on: March 20, 2013, 07:22:02 PM »
Got the heat gun out and heated the bowl up. Came right off.
Dis-assembly tomorrow and a good soak.
tt
Offline Gregorymoto
  • SOHC Aficionado
« Reply #74 on: March 20, 2013, 07:50:40 PM »
I was talking about the bike.
