Front wheel mock up.
When the parts arrive I will be installing:
New rear pivot seals. Found some at Ohio Cycle.
New brakes. Ohio Cycle.
New cables. Speedometer and brake.
New tire, tube and rim strip. Went with a 3.50-16 due to cost and limited availability of the 3.25-16 tire.
Wanted to use the one on it but due to age decided against it. Fender should be about done as well as seat. Holding off on headlight as I am shopping for stock handlebars. Ordered a headlight with replaceable Halogen bulb. Upgrading the rectifier also.
The only thing I am not happy about is the petcock rebuild kit. I wanted to use the rubber gasket on the bottom of the fuel lever but the holes were way off. Had to use the cork.
Not sure how long it will last with today's gas.
tt
