Author Topic: 1981 cb 650 valve adjustment tool  (Read 2203 times)
racing33
« on: July 22, 2006, 08:30:22 AM »
I have read several posts about a valve adjustment tool. Being the tight wad that I am I got to wondering if one could be made relatively easy? I pulled the valve covers, then I found out what size the adjuster nut was(10mm). I went to the tool box, grabbed an extra deepwell 10mm socket and cut the end off of it. Next I got a piece of 1/8''x 1/2'' flat steel and cut it about 6'' long. I set the cut off socket on the adjuster nut and held the piece of flat steel against the socket to get an approximate angle to attach it at. Took both pieces to the vise and welded them together with the MIG welder(just a cheap one). Round of the edges on the "handle", clean it all up real good inside and out. The deep well socket I used was hollow all the way through the socket and when you cut the square off the end of it it allowed you to get a screw driver through the center of it which allows you to hold the adjuster shaft for while you tighten the adjuster nut. It worked real good for me and I know I am not the only tight out there, so I thought I would pass it along to anyone who cared.
Bruce
Ibsen
Re: 1981 cb 650 valve adjustment tool
« Reply #1 on: July 22, 2006, 02:23:31 PM »
I have made my own. But I also think you can get one from Sudco:
http://www.sudco.com/tool.html
Offline cb650
« Reply #2 on: July 22, 2006, 05:48:25 PM »
I did check with honda and they still have it for 9 bucks.
               Terry
Offline rab1dwolf
« Reply #3 on: July 22, 2006, 07:00:52 PM »
just picked mine up today from honda.  not to overly complicated looking but probably worth the price
1982 cb650sc nighthawk.  the work never stops.
Offline cb650
« Reply #4 on: July 23, 2006, 06:55:13 AM »
Bought mine 22 years ago and seems I payed the same then.
                    Terry
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #5 on: July 23, 2006, 07:05:31 AM »
I bought mine from parts n' more, and it's terrible.  Spent $18 and the damn thing doesn't have the length to reach my exhaust tappets.  I've always used the go/no-go method with a screwdriver and socket wrench anyway  :)
CB750K4
Offline tomkimberly
« Reply #6 on: July 24, 2006, 05:45:27 PM »
I just picked mine up from the Honda dealer, $6.78 (with my 20 percent discount).
Tom
