Author Topic: TSUNAMI-1978 CB750 K8 DONOR TO CAFE'  (Read 71818 times)
Re: TSUNAMI-1978 CB750 K8 DONOR TO CAFE'
« Reply #275 on: September 02, 2014, 05:49:24 PM »
Great progress, Greg. The mount for the coils is nice and clean. Are those Dyna mini coils or Pamco coils?
The battery seat pan also looks clean and thought out for the seat. I like the damper material too.
Offline Tsunami
  • There's No Place Like This Place Any Where Near This Place So This Must Be "THE PLACE"!
  • Life's to Short, Carry On!
« Reply #276 on: September 03, 2014, 01:33:31 AM »
Thanks Don
Power Arc
The QT-2 quad tower dual core coil pack is used to cross fire engines with 180 degree opposed cylinders.  Each coil pack has two independent two output coils.  One coil pack is required
 for a 4 cylinder engine and two packs for an 8 cylinder engine.
 ● ONE COIL PACK CAN BE USED FOR 4 CYLINDERS
 ●  CAPABLE OF 80,000 VOLTS OF OUTPUT
 ●  EXTREMELY FAST RISE TIMES
 ● FULL VOLTAGE OUTPUTS IN MULTI-SPARK
 ●  HIGH AMPERAGE OUTPUT
 ● EASY INSTALLATION (MOUNT ONLY ONE COIL PACK)
 ●  QUICK DISCONNECT CONNECTOR
 ●  FIRES AT LOW VOLTAGES FOR EASY STARTING
 ●  SECTION BOBBIN CONSTRUCTION, NO PAPER
Power Arc QT-2 Coil Pack
80,000 VOLT
 QUAD TOWER DUAL CORE COIL PACK
[Tsunami Build Link]
CL450 early 70's
New 1973 CB750 Flake Sunrise Orange
CB350 Chopper early 70's
CB350 Cafe' early 70's
Honda Cub 90cc late 60's
Other's
« Reply #277 on: September 03, 2014, 04:21:14 PM »
Thanks Don
Power Arc
80,000 VOLT
That's lightning in a bottle.   8)
« Reply #278 on: September 04, 2014, 08:31:21 AM »
Just checked the Dynatek site.  Their coils produce in excess of 30,000 volts.  Just a bit less than 80,000.  That Power Arc coil should provide a serious spark.
Offline Tsunami
« Reply #279 on: September 04, 2014, 02:29:05 PM »
Don said it best lighting in a bottle, I like that.  On the other hand that means I have 80,000 volts of lighting less than a foot away from the family jewels!
Yep running the Power Arc Ignition as well, got them through CycleX but didn't buy the programmable Coil, s***t I haven't even begun to figure out my Iphone yet.
Got my oil pressure gauge on last night, most of the front end, and put a new connecter on the alternator wire bundle.
Still cringing at the thought of getting all these new electrics were they need to be?
Thanks for the comment guys
CL450 early 70's
Other's
« Reply #280 on: September 04, 2014, 02:37:46 PM »
Looking great. Hey, when did you make your dual horns all sparkly??
Offline Tsunami
« Reply #281 on: September 04, 2014, 04:51:23 PM »
As it appeared no one but I liked the red covers I decided to bend to the will of the people! I tossed them in the mix when I had the frame pieces powder coated.  Now just between you and me, those little bright spots in the center?  Well those are a pair of military strength lasers of more than 105 kilowatts (kW).  I have them bore sighted approx.. at 150 yds. (where the beams cross).  I haven't tested them yet but I figure that would be far enough away to allow me to evade any pieces of the target before I got there.  The hard part is setting it up to adjust the optimum point in relation to my speed.  You know there is always something that gums up the work in these custom builds.  I picked this up from some folks down your way at Northrup Grumman in Redondo Beach.
CL450 early 70's
Other's
« Reply #282 on: September 04, 2014, 05:11:49 PM »
Now you are just messing with us feeble minded cavemen.
« Last Edit: September 04, 2014, 10:52:58 PM by CB750 Cafe Racer Fan »
Offline BPellerine
« Reply #283 on: September 04, 2014, 06:01:28 PM »
Greg maybe this one will rattle the canyons too!although I don't comment often I check your thread often.you have a nice bike!bill
1978 CB 750K ard and webers
another anfob
Offline Tsunami
« Reply #284 on: September 07, 2014, 04:27:37 AM »
I enlarged the ad from cycle magazine to get a better look at the pipes, unfortunately could not find any with the meg on.
CL450 early 70's
Other's
Offline BPellerine
« Reply #285 on: September 08, 2014, 02:43:33 PM »
shiny happy bike there man,those pipes are on a bike that they tested webers on in an old mag.cool.bill
another anfob
Offline Tsunami
« Reply #286 on: September 08, 2014, 03:06:58 PM »
Actually the ad was for Tracy Fiberglass Works In Santa Cruz Ca back in the 70's. This particular ad showed one of his Cafe' set ups with the seat, tank and fairing.
Below  This was what he gave me for lending him the bike once in awhile for ads & fitment.  The tank on the 750, body with seat and tank, and paint jobs for all.
Or were you talking about another bike & mag?
CL450 early 70's
Other's
Offline BPellerine
« Reply #287 on: September 08, 2014, 04:53:07 PM »
it was in another mag,but I have never seen that exhaust in person.bill
another anfob
Offline Tsunami
« Reply #288 on: September 09, 2014, 02:22:45 AM »
Bill good luck on your nomination!
Just a weekend update here.
9-6-14  Started on the rear suspension,
did every one remember to grease their brake spindle and the pinions the shoes ride on?
How about your brake wear indicator and Rubber washer for the Brake Bar?
Shutting down the shop for the day!
CL450 early 70's
Other's
Offline Tsunami
« Reply #289 on: September 09, 2014, 02:25:03 AM »
09/07/14
mounted the chain and misc., choke cable and holders
CL450 early 70's
Other's
Offline Tsunami
« Reply #290 on: September 09, 2014, 02:31:36 AM »
09/08/14
Installed new neutral safety switch, repaired the wire, repaired one of the connections in the alternator bundle and wrapped them in tape. Installed the chain guard cover and the shifter cover as well as the left rear set.
I call the rear suspension done!
OOP's
CL450 early 70's
Other's
Offline brandEn
« Reply #291 on: September 09, 2014, 06:33:14 AM »
man things are looking GREAT
Offline BPellerine
« Reply #292 on: September 09, 2014, 05:02:21 PM »
now stick a tank on that thing and make roar!looks nice.bill
another anfob
« Reply #293 on: September 09, 2014, 05:12:45 PM »
It's all in the details, and you are bringing them together nicely, Greg.  Like those drag bars.  Everything on this bike is screaming quality.
Offline Tsunami
« Reply #294 on: September 14, 2014, 12:57:55 AM »
The 9th on I have kept busy with little things like the exhaust, some cables, found out my new banjo bolt crush washers in the 3/8 size are too small.  Of the three drill guides I have I picked the one that said it was 3/8" the other two say the next size up, I think it was 25/64 if it weren't for bad luck I would have no luck at all.  And those puppies aint cheep as you all well know.  Also have set up a paint booth with a table spinner of sorts.  I spent too much money on the Alsa Killer Chrome with less than stellar results, not something for an amateur, save your money.  But I'm toying around with a number of effects to see what I can come up with time will tell.  Anyway some pics.
« Last Edit: September 14, 2014, 01:00:06 AM by Tsunami »
CL450 early 70's
Other's
Offline Tsunami
« Reply #295 on: September 14, 2014, 04:48:37 PM »
Thanks CALJ735, You know I never gave it that much thought, didn't know it could be an issue? The two long bolts are original so I don't think it will go anywhere, what can you tell me about your research?  Yes I decided to stay with the stock gauge's as I loved them on my 74 back in the day.  I did update them with new led lights, faces, domed glass cover and the joker trim rings. I also rolled the mileage back to "0". I had a set of the chrome covers that hid the sides and they looked great but wouldn't work with the Trim rings.  So I repainted the black outside and save it to upgrade in the future.  Glad you noticed
CL450 early 70's
Other's
Offline Tsunami
« Reply #296 on: September 14, 2014, 11:14:26 PM »
Yep nothing is ever easy with these builds.  I'm going to query the people I bought them from and see what rating they have.
  I had a pair of grips with rubber and some gold copper trim as I had thought I might try to do a lot of brass.  What used to be a cheap commodity is no longer as brass has gone from scrap to jewel like prices!  So I saw these grips but they were for Harleys, Honda has a throttle tube to account for.  I tried to get a machine shop to do it but it wasn't worth their time.  I eventually had to get a 7/8" size and spend quite a bit of time with a number of different home made tools to enlarge the inside of the grip to cover the tube.  The controls I stumbled into, ain't the internet great, on line and sent the grip to a fellow in LA with the controls to route out the hole for them.  As yet not hooked up, the electrics will be a real challenge.
So what's keeping your hands greasy these days?
CL450 early 70's
Other's
Offline Tsunami
« Reply #297 on: September 15, 2014, 12:25:09 AM »
AHHHHHHHHHHHHHHHH  YES!
CL450 early 70's
Other's
Offline brandEn
« Reply #298 on: September 15, 2014, 05:17:59 AM »
That bike is so damn cool. I like it without the tank and seat. Can't wait to see it all buttoned up on the floor though.
« Reply #299 on: September 15, 2014, 10:17:53 AM »
Greg,
The bike is really coming together daily.  Love it.
The gear throttle looks cool, but those large gears would have to move like butter to work right.
