Author Topic: TSUNAMI-1978 CB750 K8 DONOR TO CAFE'  (Read 69559 times)
Offline Tsunami
  • There's No Place Like This Place Any Where Near This Place So This Must Be "THE PLACE"!
  • Life's to Short, Carry On!
Re: TSUNAMI-1978 CB750 K8 DONOR TO CAFE'
« Reply #350 on: November 13, 2014, 06:35:40 PM »
And more yet
« Last Edit: November 13, 2014, 06:37:16 PM by Tsunami »
[Tsunami Build Link]
CL450 early 70's
New 1973 CB750 Flake Sunrise Orange
CB350 Chopper early 70's
CB350 Cafe' early 70's
Honda Cub 90cc late 60's
Other's
Offline Tsunami
« Reply #351 on: November 13, 2014, 06:39:39 PM »
more yet but that's all until tomorrow.
CL450 early 70's
Other's
Offline BPellerine
« Reply #352 on: November 13, 2014, 07:30:58 PM »
cool finding all your old tools!and the bike is looking good too,bill
1978 CB 750K ard and webers
another anfob
« Reply #353 on: November 13, 2014, 08:09:09 PM »
Greg,
Great progress.  Meticulous work on the wiring.  Outstanding!
Don
Offline Tsunami
« Reply #354 on: November 15, 2014, 12:59:46 AM »
Thanks Bill, thanks Don.  Seem's like two steps forward, one step back.  But starting to see daylight at the end of the tunnel.  Talked with the fellow at Power Arc Ignitions today, quite a character but very knowledgeable on his systems and electrical over all.  Learned soldering connectors not always a good thing as well as relays.
« Last Edit: November 16, 2014, 12:26:29 AM by Tsunami »
CL450 early 70's
Other's
Offline BPellerine
« Reply #355 on: November 15, 2014, 03:57:12 PM »
soldering not a good thing?bill
another anfob
Offline Tsunami
« Reply #356 on: November 16, 2014, 12:25:48 AM »
Bill
The gist of what the man said was something like the solder makes the wire rigid and heat make it brittle and they break, then if you have shrink wrapped the connection it holds it and you start getting intermittent operation.  Which will drive you nuts trying to find it?  I did have some break after being soldered and just trying to remove them from their socket? They did seem a little brittle.  The original no solder way that Honda did it seems to be more flexible and the solder makes them rigid.
He also talked about using relays as they tend to subject to vibrations and shocks like hitting a pot hole or something causing the points to bounce.  I'm still going to try and use them as it doesn't seem to bother autos I have had them in and they get bounced too.  Just saying.
CL450 early 70's
Other's
Offline BPellerine
« Reply #357 on: November 16, 2014, 10:33:12 AM »
I guess there are a lot of ways to look at things,the no solder way seems to allow for easier disassembly but who knows!bill
another anfob
Offline Tsunami
« Reply #358 on: November 21, 2014, 12:31:10 AM »
Your right Bill, who really knows.  Are you getting a load of snow your way? Our East  area is getting clobbered!  Were finally getting some rain here in Sunny Northern California.  Unfortunately even if we have a good snow pack this year we still will be in drought conditions next year, that would be only about 1/3 of what we need to get back to normal. But I degress.
Catching up with the last few days,   Last Sunday the 16th I was hooking up the throttle and clutch cables.  When attempting to insert the engine end in the clutch housing it would not go in.  The powder guys missed plugging it up and I missed correcting while the part was off the bike, of course I didn't know I had a problem at that time.  So how to fix this without having to take the cover off again?  Hence the first picture, you might have thought to yourself "what is that contraption on the drill?" What I finally ended up with was attaching a Lexan drill bit to an old extension I had in order to thread it through the area to the hole, quite tight.  I hadn't used the extension in years so the two, the name escapes me, you know like just the threaded piece with an hex indentation on the top to screw down to hold the shank of the bit.  Both were long gone, so the search went on for something with the correct thread and not to long.  Found a machine screw with the right thread but was too long to clear the sides of the engine. After lots of grinding, cleaning and getting the threads working right I finally manage to slip the puppy in there and cut out the powder coat enough for the clutch cable to set in there properly.
Monday and Tuesday had some work.  I decided while working on the clutch I didn't like the bulging oil lines and began to correct them.  Had to remove the oil tank which was a great pain but even worse to put it back in after shortening the length of the lines.  But as luck would have it now they were both too short, Arrrrgggg
So out it all came again, shortened the long one to the correct length for the short one and luckly had enough of the line left on the shelf to make  a 1 inch longer long one and back in she goes. I think it was well worth the effort to get it right, third times the charm!  Alas while cutting one of the lines to length with my die grinder with a cut off blade managed to put I nice nick in my good thumb. the rest of the week was work and when I was able to get to the shop began to wire the AMP water-proof connecter for the seat side of the taillight/turn/stop signals.  While checking out the bike side I already had done one of the wires fell out, crap, you cant imagine how hard those tiny connections are to get out once in.  I had bought a tool made to do it, plastic of course and it busted in the first effort to get it out, that's $2.50 in the loo.  While fixing that wire ANOTHER wire came out, so had to fix it! Did I tell you how tiny those things were.  Anyway got back to where I was when I started to wire the other one which I will wait a couple of days to do just to keep my sanity.
Well winter is here with a BANG! Temps have dropped near freezing, hope I got enough antifreeze in the boat engine this year?  Well guys be safe out there, have a great Thanksgiving!
CL450 early 70's
Other's
« Reply #359 on: November 21, 2014, 06:39:37 AM »
Way to persevere, Greg!  Ouch to the thumb. That's gonna sting in the shower the next day!
Offline Tsunami
« Reply #360 on: November 21, 2014, 12:08:44 PM »
yep, by the time I'm done with this I think I could have bought two bright-red, hunch-back, warp-speed 900cc cafe racers!
Long Live the Sausage Creature !!!!!!!!
CL450 early 70's
Other's
« Reply #361 on: November 21, 2014, 12:32:16 PM »
;)  I re-read that article every so often. It's absolutely brilliant.
Offline BPellerine
« Reply #362 on: November 21, 2014, 06:09:08 PM »
well we got our first snow,not like new York but I still don't like it!did not think you guys got freezing temps,just a myth I guess,seems like the last mile on your build is a frustrating one!get mom to put a band aid on that!haha bill
another anfob
Offline Tsunami
« Reply #363 on: November 22, 2014, 12:04:36 AM »
Bill were just below the snow line here.  2006 and 2009 the year my boat engine cracked.  I'm from Minnesota so we only call this a dusting back there.
« Last Edit: November 22, 2014, 12:07:04 AM by Tsunami »
CL450 early 70's
Other's
« Reply #364 on: November 22, 2014, 04:43:53 AM »
Man, that looks cold! Brrrrr.
Offline BPellerine
« Reply #365 on: November 22, 2014, 10:40:49 AM »
just a dusting here too,but cold!you cali guys are so spoiled Don!hahabill
another anfob
Offline Tsunami
« Reply #366 on: November 22, 2014, 05:16:21 PM »
Well that was 2009, its just wet now and we will take all the wet we can get!  Hope your having a great weekend. I was cleaning old rusty tools.  Used Evapo-Rust, works good and wont kill you, enviro everything, puts that gel stuff out of business. About time too that stuff never worked that well for me and it burned like hell.  You can wash your hands with this stuff.  Just finished the waterproof plug for the tail light in the seat and after some adjustment all the lic light, brake, signals and tail light work from the headlight.  Its spiffy but I don't think it will hold up in the long run, just too fragile. Good for now!  Off to dinner, I'm bringing Merlot tonight!
CL450 early 70's
Other's
« Reply #367 on: November 22, 2014, 05:16:30 PM »
I'll admit it.  We are.  It was a nice 75 degrees today and sunny, blue skies.  Going riding tomorrow morning!
Offline BPellerine
« Reply #368 on: November 23, 2014, 03:49:45 PM »
I would too don!greg the evaporust is really good and cleans what you would think is junk to nice paintable surfaces,I know winter comes every year but I somehow dislike it more all the time!waiting to hear that your bike lives!bill
another anfob
Offline Restoration Fan
  • My wife will never call me
« Reply #369 on: November 23, 2014, 08:37:44 PM »
Was just there in LA Friday night to pick up my Jeep.  I kept thinking (and often saying), "I could really get used to this weather".  Which is also what I think pretty much every time I'm out there in Southern California.  You guys really do have it nice out there....weather and the views.
Offline Tsunami
« Reply #370 on: November 23, 2014, 11:13:59 PM »
Been busy de rusting old tools. Finished up the plug for the taillight.
El Dorado Hills, CA
Sunday 11:00 PM
Scattered Clouds 47°F | °C
Precipitation: 0%
Humidity: 82%
Wind: 0 mph
Overnight
Monday
 Sunny, with a high near 61. Light and variable wind becoming west northwest 5 to 7 mph in the afternoon.
CL450 early 70's
Other's
Offline Tsunami
« Reply #371 on: November 27, 2014, 12:09:07 AM »
This is a Bosch connector very waterproof.  Ill be running the Alternator 3 yellows, 1 black, 1 white, d. blue/red (oil pressure switch), Lt. Green/Red (neutral safety switch), through it.  I likely will not be able to use the mount but wont know until I get it done if it will work or not.  14 pins to wire, have done 3 only eleven to go. The pins are quite small but the engineering is very good.   Dam work keeps getting in the way. Now holidays bahh Humbug! So I work on it when I can, wish I could get on a roll and git er done!!!
Hope you all have a great Thanksgiving
Greg
« Last Edit: November 27, 2014, 12:14:56 AM by Tsunami »
CL450 early 70's
Other's
Offline Tsunami
« Reply #372 on: July 13, 2015, 09:44:46 PM »
Hi Guys, not dead yet!
Got waylaid on life.  Still working on wiring, I have made some small progress and hope to enlist some help soon and get this thing done before the tires rot.  I hope your all well and having a good time on the road.  I will soon post some new photos and an update of where the project is at as soon as I know?
Greg
CL450 early 70's
Other's
« Reply #373 on: July 13, 2015, 10:46:20 PM »
Greg!
Back from the great beyond!!  Glad to see you, again & looking forward to an update!!!
Don
Offline BPellerine
« Reply #374 on: July 15, 2015, 11:38:07 AM »
wondered how you were getting along!bill
another anfob
