Author Topic: rc ignition for bill  (Read 1527 times)
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
« on: March 21, 2013, 07:13:40 AM »
for bill
« Last Edit: March 21, 2013, 11:38:02 AM by neilc »
Offline neilc
Re: rc ignition for bill
« Reply #1 on: March 21, 2013, 05:48:11 PM »
more pics still cant  figure out tdc 1-4& 2-3 see other pics,black center piece is spring loaded so most be advance
Offline neilc
« Reply #2 on: March 21, 2013, 05:53:02 PM »
more pics also previous pic  of my coils on last post,talked with Bill anyone see this before,i posted earlier with no luck except sarcastic remarks,i know its 30 years old but still works great just looking for some instructions on how to set it up and find tdc
Offline Vinhead1957
« Reply #3 on: March 21, 2013, 07:14:42 PM »
Is that a viewing hole under the top screw towards the center? It is kind of fuzzy in the Picts   That is where the hole to see them should be
Offline Vinhead1957
« Reply #4 on: March 21, 2013, 07:22:43 PM »
If so there is two lines one marked T and the other marked F line the T up for 1 and 4 and then check the valves. Tappet covers off the one firing at the T which is TDC will have both valve fully closed. The adjustment tappets will have a little play.    Really should have the manual at this point.   I don't think you can adjust the 2-3, separately
Offline neilc
« Reply #5 on: March 22, 2013, 01:22:03 AM »
If you look threw the viewing hole all that is their is a centerline Mark,even when you rotate the 23mill nut their are NO markings at all
« Reply #6 on: March 22, 2013, 01:59:25 AM »
it dosent matter on the pairs 1/4 and 2/3 which valves are closed or open as its a waste spark system still,using something down #4 plug hole find tdc or thereabouts and look hard for any mark behind the unit.
that black centre piece also has a red index type mark,maybe that comes into play some where?or did you put them on,they appear missing in another shot?
maybe removing the centre bolt and larger hex nut the black centre comes off revealing the index marks?
« Last Edit: March 22, 2013, 02:12:55 AM by dave500 »
Offline neilc
« Reply #7 on: March 22, 2013, 07:38:05 AM »
the red marks were their i just highlighted them,once i find tdc on 1&4 and 2&3 i bet the red lines line up their is also a black slotted line on the advance that is part of the unit,i guess bottom line is i have 2 choices take the unit off and check for index marks,or take the valve covers off and rotate until i find them open all the way and see where the ignition lines up,make sense?
Offline Scott S
« Reply #8 on: March 22, 2013, 07:42:37 AM »
 Have you put a timing light on this thing yet? Try it and see what shows up in the window and what position the red lines are in.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #9 on: March 22, 2013, 01:23:33 PM »
pull all the plugs and #4 inlet tappet cover,rotate the engine and watch that inlet valve go down then start to come up again,now insert something into #4 plug hole and carefully bring it to tdc,your marks where ever they are should now be close.
Offline neilc
« Reply #10 on: March 22, 2013, 01:55:15 PM »
ya seems like the way to go with this thing,i post soon as i can get to it hopefully tomorrow
