Author Topic: cable instead of linkage rear brake  (Read 652 times)
Offline metalhead0283
  • speed on brother hell aint half full
« on: March 20, 2013, 12:58:17 pm »
wondering if any of ya have modded the rear brakes on your bikes to use a cable drive instead of the linkage...if so do ya got any pics? seems like it wouldnt be to hard to do
77 xs650  81 xs650  76 cb550f  2010 triumph street triple
Offline Raul CB750K1
Re: cable instead of linkage rear brake
« Reply #1 on: March 20, 2013, 02:43:26 pm »
It is not difficult, you can either use a cable from another bike, or make one yourself. You will need some welding skills to weld a bracket both in the frame and in the swingarm.
I plan to do it with a build -not a Honda- I've done. I've used a linkage, but when you are pressing the brake pedal, as the swingarm goes up and down, the brake tension increases and decreases. It is just a problem of geometry, but I can't do anything with it as it used to be a hidraulic rear brake -that I converted to drum- so my plan is to use a cable, so the cable tension will be independent of the swingarm movement.
