Author Topic: Steel clutch plate  (Read 665 times)
Offline Lost and Confused
  • Bob
  • An old fart !!
Steel clutch plate
« on: March 21, 2013, 02:08:09 PM »
Can someone tell me if this is an original stock Honda steel clutch plate. I'm changing the clutch, and wondering how old it is. The plate has dimbles in it.
Bob
Offline greenjeans
  • 1972 CB750K2
Re: Steel clutch plate
« Reply #1 on: March 21, 2013, 02:55:52 PM »
Looks like it to me.    Find a piece of glass or something that is FLAT, put a piece of 200-400 grit wet or dry paper and give them a once over.
I use WD-40 instead of water for lubricant when sanding those.
As long as everything measures up within spec when stacked up, you should be ok.
Offline lucky
« Reply #2 on: March 21, 2013, 05:08:52 PM »
Yes it is normal.
Lay the plate on a piece of glass or formica flat table top
and make sure it is not warped or discolored.
