Author Topic: Norwegian 78 cb550 (gsxr front, 592cc, EFI conversion +++)  (Read 11374 times)
Offline ISLAND CAFERACERS
Re: Norwegian 78 cb550 cafe project
« Reply #50 on: November 22, 2013, 08:18:45 AM »
hi Harald your build id looking great
can you tell me please where you got your rev counter gauge from it looks very cool
also did you cut the key loop off the top yoke ? did it need strengthening
will keep watching looks a great bike in the making
cheers Andy UK
Offline Harald F
« Reply #51 on: November 22, 2013, 08:46:38 AM »
Top yoke will be replaced bye one oft cognito's billet porn bits :)
gauge is motogadget.. $$$
Offline Harald F
« Reply #52 on: November 23, 2013, 09:49:59 AM »
Cognitomoto parts arrived :D
cant wait to put this on the bike, looks amazing compared to the stock gsxr piece.
Offline Harald F
« Reply #53 on: November 24, 2013, 09:37:37 AM »
tried the new parts on. also smoothed and polished the stock GSXR steering tube to make it match the triple tree. still need to do the other side. and the lower, stock part of the triple..
« Last Edit: November 24, 2013, 09:53:51 AM by Harald F »
« Reply #54 on: November 24, 2013, 11:17:03 AM »
Is the GSXR steering stem a direct match for the 550?  With the 750, it needs a longer stem.
Offline Harald F
« Reply #55 on: November 24, 2013, 01:17:10 PM »
on the 550 its a direct match. change bearings, add a steering stop, voila.
Offline Harald F
« Reply #56 on: December 08, 2013, 01:29:48 PM »
Mini update.
brake discs arrived.. 320mm, so i need to add a small spacer for the caliper to clear.
a friend reluctantly posing with the new bits.
also started with the electronics.
padded batterybox will be made fuses and relays mounted to it.
the regulator... does it need to see air flowing over it to function without overheating?
any tips here would be helpful
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
« Reply #57 on: December 12, 2013, 07:14:57 PM »
You could tuck it in under the neck of the frame above the coils, the way Hannibal did. Of course everything he did was custom machined so...
« Last Edit: December 13, 2013, 05:42:18 AM by deafcaferacer »
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
Offline Toustic
  • I can levitate birds... But nobody cares
« Reply #58 on: December 15, 2013, 11:35:36 AM »
Hei, Hvordan går det?
(That's all I know.. Should have asked my teammate and roommate from Sola to teach me a bit more I realize).
Subb'ing on this thread. I'm loving what you're doing with this.
Not even 12 hours ago I was looking up Gsxer's front ends and that Cognito triple tree, doing the math  ::). It's nuts that I land on your thread a few minutes ago and get to see what it would look like. Looking forward to see where this goes.
"I totally take back all those times I didn’t want to nap when I was a kid."
Offline rb550four
« Reply #59 on: December 15, 2013, 02:19:45 PM »
Just caught up with your tread , nice job . Would that rectifier/ regulator get enough air if it was mounted on the underside of where it is in your pic?  And still wire up under the seat or are you looking for a super clean, nothing visible  look?
Offline Harald F
« Reply #60 on: December 26, 2013, 03:24:20 PM »
made a bracket to hold the motogadget tacho.  tedious work, but i think it is worth it.
« Last Edit: December 29, 2013, 05:57:19 PM by Harald F »
« Reply #61 on: December 29, 2013, 11:50:04 PM »
Nice.  Can we see a picture from the reverse angle (from the front and underneath) to show the bracket?
Offline Harald F
« Reply #62 on: December 30, 2013, 06:20:14 PM »
got the headlight mounted.
starting to get a feel for how this is going to look when finished :)
Offline Harald F
« Reply #63 on: December 30, 2013, 06:24:42 PM »
not really sure how hot it gets and therefore how much cooling air it would need.
I would prefer to have it completly hidden, for a super clean look.
« Reply #64 on: December 30, 2013, 10:43:29 PM »
Looking good, Harald
Offline Harald F
« Reply #65 on: March 01, 2014, 02:15:29 AM »
slowly starting to look like a bike again..  in a week or so, the rear wheel will be laced up(waiting for spokes).
happy with the look of things so far :)
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #66 on: March 01, 2014, 08:32:57 AM »
This is really starting to take shape.
Nice work.
Offline tweakin
  • tear down
« Reply #67 on: March 01, 2014, 09:07:38 AM »
^^^  Agreed, looks great.
Offline Godffery
  • Godffery's Garage
« Reply #68 on: March 01, 2014, 09:49:44 AM »
Yes, coming along Nicely!  (8 d')
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #69 on: March 03, 2014, 08:22:00 AM »
Looking good!
www.CognitoMoto.com
www.CognitoMoto.com
GSX-R Fork Conversions/Laced Hubs and Cafe Racer Parts
www.facebook.com/cognitomoto
Offline Harald F
« Reply #70 on: March 03, 2014, 01:08:23 PM »
working on extending the very short seatpan i got a little bit so i can actually fit(even tho im no fat guy).
details details..
Offline Harald F
« Reply #71 on: May 10, 2014, 11:19:01 PM »
made a tank strap out of stainless steel, drilled and countersunk along the top, just for looks. spring loaded clamp in the front.
happy with the look of this part :)
seat welded up.
happy with the results.. just smoothing and polishing left on it now.
this stock dust cover over the steering bearing was ugly.
a new part was machined to replace it :D
also got spacers for the calipers to get them to clear the 320mm discs, and plugs for the rear of the frame. the spacers are alu, and the plugs are steel and will be welded in, and then grind down the weld.
details take a LOT of time.. but the devil is in the details..  i hope?
approved ?
« Last Edit: May 10, 2014, 11:20:58 PM by Harald F »
« Reply #72 on: May 11, 2014, 12:19:41 AM »
Great work.  I like how the tank strap came out.
Offline snowman
« Reply #73 on: May 16, 2014, 05:28:46 PM »
Looks great, keep up the good work can't wait to see the end product.
Sent from my iPad using Tapatalk
Offline Harald F
« Reply #74 on: July 18, 2014, 02:16:54 PM »
cognito moto sold me a set of the new fox podium R shocks..  will probably powdercoat the spings gloss black but other than that they look really great and were easy to fit. Had to adjust the lengt of the bushing that goes in the top, so it matched the width of the stock bolt on the cb550 frame..  also got a lot of other bits and pieces today and will carry on building as soon as possible,
