Well having a bit of trouble with the T/belts on my GL1000. I've come to the conclusion that it must be the Napa belts. I have to fight with these @#$%^ belts to even get them on the sprockets. It takes a lot to make me cuss like a sailor, but I've used words in the last few days that I haven't used in years
Being so hard to get the belts on it's hard to keep all the timing marks lined up and not move. I know it shouldn't be that hard to get these belts on. I've had these belts on and off half dozen times(my hands are sore) trying to get marks dead on. All the how to video's on web sites show the belts go on pretty easy and one and in some cases they don't even remove the radiator. This last time the marks were almost dead on, but not quite. So I took them back off, maybe I shouldn't have, but they just seemed to tight. By what I've read on several GW sites Napa #250274 is suppose to be the OEM replacemet belt for the 1977 GL1000. But somethings wrong, it's like their just a fraction to short. Maybe the teeth are cut different. I've always told myself with these old Honda's, if the factory parts are still available go that way because you know they will be right even though in some cases the $$ is double or triple the price of aftermarket. I thought I would save a little money and it bit me. Well two Honda #14400-371-014 belts on order from Servicehonda at $63.66 each. Ouch, but I know they will be right. The local Honda dealer wanted $85.00 per belt. Hope these belts will go on easier and line up and everything will be good.
Has any other goldwingers here run into the same problem with trying to use non factory belts on there GW?
