In the next week or so I think I'll attempt a start-up. I'm not sure, but it was last plated in 76. what i can see of the motor, it's in near mint shape. I drained the oil, it was in good shape. Someone may have changed it recently. it's not seized, turns over nicely.
Question.....should I spray something in the spark plug holes? A bit of oil? WD40?
I plan on filling the oil, as per some suggestions (maybe Hondaman? ) said, put 2 quarts in the tank, let 1 quart run in thru the tappet adjusting holes. Then turn it over with the plugs out and make sure the oil pressure light goes out.
Any other snippets of advice?
Thanks in advance, John.
