Author Topic: 3 out of 4 is BAD...Need a little help  (Read 3258 times)
Offline Blackhole
Re: 3 out of 4 is BAD...Need a little help
« Reply #25 on: March 31, 2013, 05:42:51 PM »
Well we removed the carbs and cleaned the idle jets with a guitar string and the bike starts right up on the first kick.  The only thing is it has a small pop coming from either 2 or 3 when it is idling.  I did make sure that I put a different plug in #1 so now I need to see if the one that came out of #1 is now in 2 or 3 (I numbered them).  We also made sure that the acceleration circuit was clean.  When I would spray carb cleaner in the small hole then put air to it you could see it spray in all four carbs.  When you grab a hand full of throttle at idle the bike will die but if you roll into it it is fine.  Just over 2000 you can grab as much as you want the it runs like it should.  I hope everyone had a nice Easter.
Offline lucky
« Reply #26 on: March 31, 2013, 06:15:25 PM »
Thanks Lucky, for "Stating the bleeding Obvious", as usual................  ::)
Remember that there many beginners on this forum.
You may know all of this stuff, but many know almost nothing.
