Hope you don't mind straying off topic for a bit yesteryear.
Bryan the late model hub in my race engine became quite loose on the rivots, but the hub itself was worth saving so I took it apart thinking I might rebuild with parts from an older tighter hub. I sent this German man an e-mail asking if I could buy a set of rubbers.
Turboguzzi has suggested welding the plate to the primary gear then re-rivoting. For sure this eliminates one problem but will undoubtedly create another. I'm certain without damping of the hub the plates/discs will notch the aluminum hub/hub center very quickly. Plus all the stress is on the rivots, keeping them tight might be difficult.
Welding is an option, I'll see if this guy responds. Any other ideas...I'm all ears.
