Author Topic: Front brake upgrade for my racer  (Read 7267 times)
Offline Gman
Re: Front brake upgrade for my racer
« Reply #25 on: April 15, 2013, 05:17:22 AM »
The Suzuki rotors are 274mm. You could work over a CB750 disc, they are 295. Thin it, slot it, drill it, to reduce weight......or keep looking for something else!
Check Godffreys Garage... He has cb750 rotors already thinned and drilled, if that's something you might consider.
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/album185/Brake+Rotors+_+Thinned+and+Drilled/HONDA+Front+brake+rotors+CB750+K+-+F/
He's under the Good Sellers on the forum.
G
« Last Edit: April 16, 2013, 11:59:28 PM by Gman »
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
