Author Topic: t-bolt clamps on intake boots?  (Read 1034 times)
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
« on: March 31, 2013, 06:57:09 PM »
Anyone successfully switch out the stock "stretchtastic" intake band clamps for t-bolt clamps? I did a quick search but I'm not seeing anything right off wonder before I go in for $6.00 a clamp.
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
Online Stev-o
Re: t-bolt clamps on intake boots?
« Reply #1 on: March 31, 2013, 08:04:16 PM »
How wide are they?
Offline bjbuchanan
« Reply #2 on: March 31, 2013, 08:06:10 PM »
I haven't seen anything for what I think is a reasonable price for clamps. What I have noticed and am going to do is to straighten the mating surface where the clamp ends tighten. The get bent inward towards eachother and make it harder to tighten the phillips head. I'm gonna flatten them up because on the one or two I have done this to they clamped better
Also get some fresh bolts in there not the worn out JIS stuff
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
« Reply #3 on: March 31, 2013, 08:34:07 PM »
y2k ; Not sure the model your wanting to clamp but there is a guy over at "Hondachopper" that sells some killer Stainless clamps. There not T-bolt clamps but have the rolled edges that won't cut your boots plus they're stainless. Lots of guys over there use 'em. I've bought a couple of sets myself, not because they broke just needed a couple of sets. You might give him a shout ! Here is a link to the Hondachopper page where he llists them, http://hondachopper.yuku.com/topic/12545/Stainless-Steel-Intake-Boot-clamps   . Like I said Nice clamps and not bad price either.   ...cougar...
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
« Reply #4 on: March 31, 2013, 11:33:23 PM »
Big thing is they need to be no wider that the originals or they will distort the rubbers and alow air leaks
Offline y2kc0wb0y
  • B00msh0cka
« Reply #5 on: April 01, 2013, 03:58:52 PM »
TY great fine. I was having a hard time locating these type clamps, I'm sure like others, for a reasonable amount of money. Hopefully the will work with PD carb boots.
Offline dlhoulton
« Reply #6 on: April 01, 2013, 04:35:05 PM »
They work. Here's a shot of them on a 78F:
« Last Edit: April 01, 2013, 04:38:05 PM by dlhoulton »
« Reply #7 on: April 01, 2013, 06:14:20 PM »
Are those aftermarket insulators on your F2??
Offline y2kc0wb0y
  • B00msh0cka
« Reply #8 on: April 01, 2013, 06:39:43 PM »
I believe they are stock
Offline dlhoulton
« Reply #9 on: April 02, 2013, 03:24:26 AM »
They are aftermarket. Got them from: http://www.claussstudios.com/id45.html . Go to bottom of page.
« Reply #10 on: April 02, 2013, 08:41:21 AM »
That's what I thought. I don't mean to get off subject but how are they working? Is the material super flexible and almost spongy or is it more rigid and solid. I ask because a customer of mine has an F2 head I just ported and I haven't handled those insulators.
Offline dlhoulton
« Reply #11 on: April 02, 2013, 11:28:11 AM »
I wouldn't call them "spongy" but they are flexible. Very easy to get on and off.  I've only had them a few months. Had to order another set because I over tightened #4 and did not have it seated properly and put a tear in it. I don't think they are as tuff and thick as OEM. But then most OEM ones I've seen are 30 plus years old and have had time to harden. With those clamps we've been talking about you can easily over tighten them and cause damage to the insulators even though they have rolled edges.
Offline y2kc0wb0y
  • B00msh0cka
« Reply #12 on: April 02, 2013, 12:01:29 PM »
Got the last set of these clamps from the Honda Chopper's guy. I will be aware to not over tighten them.
« Reply #13 on: April 03, 2013, 06:47:11 AM »
I understand. It would be nice to get some feedback after using them this riding season....very interested to know in how they hold up to the ethanol.
