Author Topic: tusk valve compressor tool for cb350f -- works ok !!!! diagnosis / long read.  (Read 1241 times)
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
the engine on my cb350f project has 11K miles it (hasn't run since 1985) and am very happy with what i've found so far.  no pieces/parts and very little sludge in the oil pan, oil pickup screen was clean, engine internals when viewed from underneath look new.  no engine cover leaks.  #1, #2, #3 exhaust ports are dry but sooty,  #4 exhaust port is very oily.
i removed the head to check it out.    piston tops are sooty, except #4 is oily.
i cleaned up the compression chambers and filled them up with light oil last night.  chambers 1, 3 and 4 were still full (even tho i noticed a very slight dribble of oil in the exhaust port on #1).  combustion chamber for #2 drained out thru the exhaust port.
since #1 and #2 had leaked oil but had sooty exhaust ports, am assuming i'll need to lap the exhaust valve seats.  insufficient seal allowed some blow-by, but valve stem seals are good.
since #4 didn't leak oil, but had an oily exhaust port, am assuming the valves are sealing properly but i have a valve guide seal leak there.
my plan is to refresh the head by lapping the seats and replacing valve guide seals.  sound logical?
i'd prefer to purchase an inexpensive valve spring compressor rather than modifying a c-clamp or fabbing something.
have done a search and wondering if anyone can confirm that the "tusk" brand L235-689 compressor tool works ok on a cb350f ?  they're available at rocky mountain atv and amazon for about $39.
« Last Edit: April 05, 2013, 03:53:35 PM by steam-powered man »
searching for a dr350se
Offline hoodellyhoo
  • CB350F
Sounds right to me. I'm going to be doing the same thing as you (top end refresh) this spring. I was looking at the same valve spring compressor. It sure looks like it would work just fine.
"tusk" brand spring compressor was highly recommended by someone named "camel-toe man", so that's good enough for me.  just ordered one from rocky mtn cycle, $41 shipped, be here by monday.
i'll let you know how it works out,
regards.
bobp
Offline camelman
  • Man... Myth... Legend
Mmhmm, "camel-toe man". Guess i'm not selling you that ported cylinder head after all. ;)
That's a great valve spring compressor. Works as well as you could hope for.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Holy Smokes!!!!!!!!!!!!!
ordered my spring compressor from rocky mountain atv wed at about 6:30, arrived today in vt at noon!  great folks on the phone, fast shipping, Tusk tool is great quality.  very happy customer!
anyhow, disassembled the valves and it took less time than to write this.  tool is super easy to use, and fits the spring caps (3 cup sizes included) just right.  more good news, guides are perfect!.  off to lap the valves (looks like they taste terrible) and install guide seals.
ps  purchase was made on the camelman's advice in a search, many thx dude!   ;)
pps   an 8-32 socket head allen screw with a nylock nut opn the end makes a perfect adjuster tool    ;)
« Last Edit: April 05, 2013, 03:53:07 PM by steam-powered man »
