Author Topic: carb float height.  (Read 4539 times)
paul_D
carb float height.
« on: April 03, 2013, 05:24:44 PM »
1972 cb500 with 649A carbs
How precise does the carb float height need to be ? Ive measured mine and they vary from 22 to 23mm
Offline Mo
Re: carb float height.
« Reply #1 on: April 03, 2013, 06:46:36 PM »
I used a set of calipers to set mine, and they're within that range. They're fine, and don't overflow. Just make sure that they don't overflow, but also that they arent too low, or else the bike won't get fuel in the jets and may not send fuel to some cylinders.
Offline bjbuchanan
« Reply #2 on: April 03, 2013, 09:42:37 PM »
I would say the closer the better obviously. Make sure the individual floats in the carb are at the same level. Overlooked sometimes. a mm or two does make a difference though
« Reply #3 on: April 04, 2013, 04:52:51 AM »
That's OK. Don't worry about a mm more or less. Float heights are ALWAYS right unless people thought it necessary to mess with them before (most of these people are in this forum).
BTW, interesting to see somebody in Canada has 649A carbs. Did your 500 come from Europe?
« Last Edit: April 04, 2013, 04:55:01 AM by Deltarider »
Offline lucky
« Reply #4 on: April 04, 2013, 07:08:26 AM »
I agree completely.
IF it has not had new float needles in two years of riding, get new ones but do not try to adjust the floats to get them to stop leaking.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: April 04, 2013, 02:16:25 PM »
Your best bet is to get a clear tube float level tool. It screws into the drain screw and will give you the level while the carbs are on the bike. Should be a mm or 2 below the lip of the carb bowl.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline bjbuchanan
« Reply #6 on: April 04, 2013, 05:45:15 PM »
I can't understand the persistence to use the clear tube method. I don't get what is so killer about getting the rack off of there and making sure it is spot on to where you want with no guesstimation. You can check out the rest of the rack at the same time too. I have a 750 with stock airbox so I know it is not exactly fun either
paul_D
« Reply #7 on: April 05, 2013, 09:07:34 AM »
Yes the bike is from europe, I dont recall where. The bike is a mismash.
cb500-2057419    stamped 1974
cb500E-2145923
and 649A carbs with 125 main jets (PO) and no hump ram intake under the seat.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: April 05, 2013, 09:46:03 AM »
Sorry to be in such a fiesty mood today but if you can't understand it then i am not going to explain it.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
« Reply #9 on: April 05, 2013, 09:56:33 AM »
..easy there D!  ;D
..because a change of 1mm in float height equates to more than 1mm change in bowl fuel level.
both my 350 and my 750 run best when the bowl fuel levels are correct (@3-4mm below bowl gasket seam).
sometime this level is achieved the shop manual float height suggested setting, sometime is not.
ie. 350F shop and clymer sugg 21mm.  23-24mm gets you the correct bowl fuel level height fi you have stock 350F floats.
none of this can be completed/dialed in without a clear tube.
Offline bjbuchanan
« Reply #10 on: April 05, 2013, 06:28:12 PM »
Bluntness comes across too harsh through typing it wasn't intended to be too rough. I understand the principle and the usefulness but I still believe that getting the rack off there and being sure of the actual measurement is best.
I don't like to recommend the clear tube because it seems like guys that aren't sure what they are doing try to half @ss it and then can't figure out why it didn't work. I'm not saying the thread poster can't get it but still, IDK
Offline lucky
« Reply #11 on: April 06, 2013, 05:06:23 PM »
I do not understand that either.
Even the shop manual says to measure the floats BEFORE.... using that clear tube method.
« Reply #12 on: April 06, 2013, 08:04:36 PM »
I don't understand the reluctance to accept the clear tube as the ONLY accurate measure of the level in the float bowl. The bench measurements are a good starting point, but the clear tube tells you what is really happening. ;)
« Reply #13 on: April 06, 2013, 08:18:56 PM »
Remember what the goal is.  PROPER FUEL LEVEL.
Can you see fuel level through your bowl?
Offline lucky
« Reply #14 on: April 07, 2013, 09:16:27 AM »
The proper fuel level is achieved by taking a measurement of the float as shown in the shop manual.
 Photo at the bottom of Page #125. Chapter 6
Offline Joemac
« Reply #15 on: June 03, 2013, 11:37:34 PM »
Can you recommend where i can get one of these?
Offline disco
« Reply #16 on: June 04, 2013, 05:02:53 AM »
+1 to what Scottly & Flybox said....the aim is to get the proper fuel level across all 4 bowls. Start by using the measurements to get it in the ballpark & then check it using the clear tube. Make adjustments as necessary.
« Last Edit: June 04, 2013, 05:25:07 AM by disco »
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline HondanutRider
« Reply #17 on: June 04, 2013, 05:16:31 AM »
It's been described before, elsewhere in this forum:
Take a section of clear aquarium hose and in a middle section gently heat it up (e.g. with a match held below).  Rotate and pull the tube so-as to stretch and shrink the heated portion.  Cut the shrunken section in the middle to create two pieces of hose that can be stuffed/screwed into the float bowl's drain hole to make a "reasonable" seal that will hold fuel while you do the test on a non-running machine.  By making four sections of hose this way, and looping the ends upwards while you turn on the petcock to fill the bowls, you can see the level of the fuel in the bowl by how high it goes in the tubes.  The seal is temporary and precarious, so you wouldn't want to leave the tubes installed while running or operating the motorcycle. ???
Offline Eddie
« Reply #18 on: June 04, 2013, 05:32:44 AM »
Also, wouldnt the float height change if the front or rear of the bike is higher or lower ? (saggy springs, different tire sizes, modifications) . So I can see the clear tube is the best method.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #19 on: June 04, 2013, 08:39:47 AM »
Yes it is but floats can get stuck when installing the float bowl or the leaf spring can get twisted a bit and block the flaot from working properly, all kinds of s#&%#(*! can happen from the time you set your floats and start the bike up.
Joemac I got mine on ebay I see them all the time for cheap.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline lucky
« Reply #20 on: June 04, 2013, 01:09:30 PM »
I have said this over and over.
The Clymers workshop manual specifically says to measure the float height and they show a photo.
It also says, To MEASURE the float height BEFORE using the clear tube method.
I worked in a dealership and we always just measured them like the book shows.
We never used the clear tube method and we never had any problems.
But you must have new float needles.
You cannot use old worn out float needles and get good results.
The float operation and float needle is 90% of making the carb work right!
