Author Topic: Looking for worn out RC engineering parts.  (Read 4250 times)
Offline gschuld
« on: April 07, 2013, 03:53:48 PM »
I know it's an odd request, but I'm looking for RC engineering parts that are too worn or damaged to re-use.  Lightened alternators, cranks, rockers, cams, pistons, golden rods, super rods, big block, springs, retainers, ARD magnetos, whatever.   I have a little research project going....
mildly damaged to totally destroyed welcome.
George
Offline Bill/BentON Racing
    • BentON Racing
Re: Looking for worn out RC engineering parts.
« Reply #1 on: April 07, 2013, 04:59:28 PM »
Check your pms , was back in the cave, found something Jr. mighta stamped! Bill
BentON Racing Website
BentON Racing Facebook
Offline gschuld
« Reply #2 on: April 07, 2013, 05:43:46 PM »
NICE ;)  Thanks
Offline gschuld
« Reply #3 on: July 01, 2013, 05:28:57 PM »
Bump
George
« Reply #4 on: July 29, 2013, 04:29:16 PM »
George, check your PM's mate... ;)
Offline AdrenalineReaper
« Reply #5 on: July 30, 2013, 07:45:39 PM »
Are you wanting to buy them, I have a rc points cover,scratched bad, and a distributor missing the drive gear
1975 Moto Martin 836cc turbo
1977 Seeley 890cc + 1/4 stroke dual weber
1970 cb750k0 turbo drag bike
1970 cb750k0 810cc w/Daytona cam
1981 cb650c café racer
Online scottly
« Reply #6 on: July 30, 2013, 08:25:33 PM »
Good luck finding the drive gear, as they as they are as scarce as rocking-horse #$%*... ;)
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #7 on: July 31, 2013, 05:07:45 AM »
george i have a cam sprocket, not slotted, but drilled
Offline gschuld
« Reply #8 on: August 01, 2013, 03:51:44 PM »
PMs sent! ;)
George
Offline BLUE71TURBO
« Reply #9 on: August 01, 2013, 07:02:00 PM »
                    If you are talking about the gear at the bottom of the distributor, it is a stock Mallory part from their VW distributor.  A special note.... The distributors used in the RC Engineering angle drive run in reverse rotation. That means the points cam and advance mechanism are reversed. So you can't use any VW designed distrbutor or magneto in the RC Engineering angle drive setup unless it is setup for the reverse rotation.   ;)
Offline gschuld
« Reply #10 on: April 29, 2015, 05:51:56 PM »
Just bumping this back up, it's been a while, but I'm still interested in dead or alive RC stuff.
George
Offline NalleyRacing
  • 1972 Cb750K dragbike Instagram: Drag_racer736
« Reply #11 on: April 30, 2015, 03:07:23 AM »
Talk with Mike Rieck. He has four of my heads and the unusable one had RC anodized retainers and was even stamped RC ENG on the bottom if I recall correctly.Along with the name STEAKLEY and BOB etched on the bottom.. I also have a 71mm block done by RC with the stock "736cc" stamp removed and replaced with just the number 1000. It has the standard copper O-ring's and a small corner of the block was shaved to accommodate the plate for the Hilborn fuel pump drive.
« Last Edit: April 30, 2015, 03:12:28 AM by TreyAllen »
Offline gschuld
« Reply #12 on: April 30, 2015, 04:17:22 AM »
Trey, I sent you an e-mail :)
George
Offline Big Jay
    • CBRzone
« Reply #13 on: April 30, 2015, 11:41:24 PM »
Got a couple of fueler cylinder heads...... Oh wait, we are going to be using them again   :P
Offline gschuld
« Reply #14 on: May 01, 2015, 02:11:31 PM »
Not nice Jay ...not nice. ::)   ...;D    And what happened to all the take out parts from those heads?
George
Offline Big Jay
    • CBRzone
« Reply #15 on: May 01, 2015, 05:40:45 PM »
Talk about parts? They will be getting the same parts we used in the triple heads.
« Last Edit: May 01, 2015, 11:40:47 PM by Big Jay »
Offline gschuld
« Reply #16 on: May 01, 2015, 05:49:31 PM »
That's great.  I was just asking about whether the parts coming out for good were getting saved or tossed.
George
Offline jkbarberie
  • Former RC Cobra back to stock.
« Reply #17 on: May 01, 2015, 08:03:20 PM »
I have a non working RC engineering electronic ignition.  I also have a duplex chain and sprocket set but I don't know if they are from RC engineering.
Jeff
1964 Honda 300 Dream, 1972 Honda SL350K2, 1973 Honda SL100, 1978 Honda CB750 F3
Offline Big Jay
    • CBRzone
« Reply #18 on: May 01, 2015, 11:41:57 PM »
George
  Never gave it any thought. I will run it past Russ.
    • BentON Racing
« Reply #19 on: May 02, 2015, 01:42:25 AM »
There's money in them parts! Awesome history, great memento's and gifts. Bill  ;D
Offline gschuld
« Reply #20 on: May 02, 2015, 03:27:59 AM »
George
Jay,
yes please do.  I'm pretty sure Russ would want to keep the take out parts
jkbarbarie,
Pm sent.  Thanks
George
Offline Big Jay
    • CBRzone
« Reply #21 on: May 04, 2015, 10:10:43 PM »
You sure you want this stuff? It probably has Russ Collins DNA on it?
Offline gschuld
« Reply #22 on: May 04, 2015, 10:18:39 PM »
If Russ Jr doesn't want it, than yes, I do.  Not sure I want any DNA though :o
George
