Author Topic: Help with CB500f carb tuning  (Read 6360 times)
Offline MotorFist
    • MotorFist
« on: April 07, 2013, 05:32:04 PM »
Hi everyone!
It's about time to start riding here in Idaho so I cleaned my carbs yesterday and in the process adjusted float height to the 22mm the manual suggests. They were all off quite a bit as I have never adjusted them before. They were around 18mm give or take 1mm.
I also changed the pilot jets as I could just not seem to get them clean no matter how much a soaked and sprayed and blew compressed air through them.
 I replaced the needle and seats too as all the old ones showed wear on the needles.
The bike has stock air box with lid removed and Marving exhaust. I am running stock jetting. #40 pilots and 100 mains.
When I rode it last summer it ran pretty good but I have always had a hanging high idle problem. Now it is MUCH worse. My Carbtune is at a buddies house and I will get it back tomorrow and sync the carbs. Hopefully that will help a bit. I may be jumping the gun by even asking questions before I sync the carbs but thought I'd give it a shot.
I attached pictures of what the plugs look like after a WFO plug chop. The electrodes look lean to me but the rings look ok? Except number 2 plug. It's less lean than the others. I didn't have a lean issue last summer. If anything it seemed fat on the top end. I am now thinking that was due to bad float heights and needle valves that were grooved.
Is it possible that syncing the carbs can help with my new lean problem? What do you think of the plug color?
Thanks in advance for your feedback!
Josh
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline Vinhead1957
Re: Help with CB500f carb tuning
« Reply #1 on: April 10, 2013, 10:58:29 AM »
I'm thinking you have one carb not working properly
« Reply #2 on: April 10, 2013, 02:35:44 PM »
with your 4 into 1 exhaust, and ? intake(cant tell what you have in the pic)...They all look lean.
dont do your carb sync until you have done your valve adjustment, set your timing/advance, and adjusted your cam chain.
oil/oil filter/air filter changed recently?
once this is done, and if you STILL have a hanging idle, verify you have no vacuum leaks
lean + hanging idle makes me think vacuum leak.
if your WOT chop comes back again looking like that, and all the above has been done, you'll need to up jet size until its right, then address the mid range chop and needle clip position.
« Last Edit: April 10, 2013, 02:39:28 PM by flybox1 »
Offline iron_worker
« Reply #3 on: April 10, 2013, 02:40:04 PM »
Is it a hanging ilde or just an idle that is way too high and never comes down no matter what? I hanging idle means you rev it up and it hangs there for a while and comes down.
I ask because if the idle is too high at all times it may be that you have the sync adjusters too far in and the slides are not bottoming out anymore.
What was your method of bench syncing the carbs?
IW
Offline Scott S
« Reply #4 on: April 10, 2013, 05:21:56 PM »
 And therein lies your problem. I went through the SAME thing on my CB500. It's the poorly designed aftermarket pilot jets.
 They're too short and don't stay submerged in the fuel in the float bowls. The holes are not the correct size nor are they spaced properly. You're idle is hanging because it's lean. It's lean because the pilot jets are crap.
 Find some genuine Keihin jets and try....I bet it will solve your problems.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline MoMo
  • Ride like you're invisible
« Reply #5 on: April 10, 2013, 05:30:51 PM »
If you have those short jets you need to get rid of them asap.   Sync does not affect mixture...Larry
Offline MotorFist
    • MotorFist
« Reply #6 on: April 10, 2013, 06:24:49 PM »
Thanks for the reply guys!
I actually didn't use those short jets. They looked looked wrong so I didn't use them.
After looking at some other topics regarding carb sync I think I am ready to go take another crack at it right now
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline MotorFist
    • MotorFist
« Reply #7 on: April 10, 2013, 09:58:49 PM »
IW
Well the correct answer about bench syncing is: I didn't. Then when I saw your post tonight I pulled them again and benched synced using the 1/8" drill bit method. After that I was able to use my carbtune. I bought a carbtune but I am pretty green with it.
So my problem now is my idle. Sometimes it hangs at 2,000 rpm and then falls really low and stalls the motor. Sometimes it will hang at 2000 rpm and then climb to 4000!
Bad news is it didn't use to have a climbing idle. It would just hang at stop lights etc. when I went through my carbs, the float height was way off spec. None of them were equal but they were all around 18mm. I adjusted them to 22mm.  I wonder if this could be part of my new problem?
I live at 4800 feet and am running the stock main jet size of 100 and a foam filter in the stock air box with no lid. I wouldn't think I'm too lean but obviously I am missing something. I used to work at a Yamaha dealership as a teen and they would always drop the main jet two sizes for our elevation when they would set up a new unit.
It may also be worth noting I never ride below 4800 feet. We usually ride the twisty mountain roads nearby which climb up to 6500 on the top of the passes.
When I had my carbs off, I checked my air box boots and intake boots and didn't see and cracks or loose clamps. Even though the clamps aren't loose, I did see some grime that concerns me about leaks. I attached a picture and you can see grime on both ends of the intake manifold. All clamps and nuts are tight.
I really appreciate the replies so far and hope you keep the coming!
Thanks,
Josh
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline MotorFist
    • MotorFist
« Reply #8 on: April 10, 2013, 10:50:16 PM »
Ok so I took a little video too. Albeit not a very good one. The idle self increases to 4000 rpm then I use the choke to drop it to 2000 where it hangs for a moment and then drops again.
Maybe this will help some of you smart guys help me diagnose?
Thanks
http://youtu.be/ilD2wSjhrHk
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
« Reply #9 on: April 10, 2013, 11:41:52 PM »
if everything else is solid replacing the o rings at the manifold to head might be worth doing,they get rock hard and stay flat,you should be able to wrangle them in without removing the rack fully.
Offline iron_worker
« Reply #10 on: April 11, 2013, 07:41:11 AM »
Agreed. Check again for vacuum leaks. Take a propane torch *not lit but with the valve open* and allow some propane to flow around the carb intake boots with the engine idling. If the idle suddenly rises then you've found your leak point.
IW
Offline MotorFist
    • MotorFist
« Reply #11 on: April 11, 2013, 09:53:26 AM »
Thank you both for the suggestions. I like the propane idea. I didn't want to use carb cleaner very badly and this sounds much less messy and damaging.
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
« Reply #12 on: April 11, 2013, 10:02:57 AM »
WD-40 works just as well, too, but I prefer carb cleaner as it doesnt leave anything to clean up  ;D
Offline MotorFist
    • MotorFist
« Reply #13 on: April 11, 2013, 12:11:11 PM »
I was under the impression wd-40 was changed a few years back and is no longer flammable?
I do have lots of carb cleaner though ;)
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline MotorFist
    • MotorFist
« Reply #14 on: April 11, 2013, 09:18:48 PM »
Well I sprayed carb cleaner to no end and couldn't find any leaks so that is ruled out. I did however notice the throttle lever that the cables hook to on the carbs was not in the right spot. Basically if the throttle grip was pushed forward, the throttle lever on the carb rack was still at least a quarter inch for hitting the eccentric pin.
So I fiddled with that and found some immediate improvements but still had a hanging idle. Just for curiously sake I gently pushed down on the big cap nuts that at next to the throttle sync adjusters. Low and behold! When I pushed down on all for of them my idle dropper to normal. Push a little hard and the slides fully closed and shut off the bike.
So it appears my slides aren't going back down all the way. I feel like a major jackass because I was lazy when I cleaned my carbs and didn't pull the slide assemblies out. :(
So I pulled one slide assembly out before I called it a night in the garage. It looked a little dirty but not enough to make it stick it I think? I will see what the other three look like tomorrow night.
For reference, the needle I pulled out says 272304 and the clip is in the position of one up from the bottom. What should it be on a 72 500?
Also if my other slides look as clean as the first, what else could be the culprit that is keeping my slides returning home? Do the springs on the throttle lever stretch over time? It feels plenty stiff when I move the throttle lever by hand. I wish I would have paid closer attention to see if the idle was hanging after a throttle snap or just when it was twisted and let go gently. I'm still learning...
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
« Reply #15 on: April 12, 2013, 12:11:19 AM »
that clip should be in the middle,its common for people to richen it like yours when a 4-1 pipe is fitted as a matter of course,most run fine with it left in the stock position.
Offline Scott S
« Reply #16 on: April 12, 2013, 05:32:29 AM »
 If you didn't pull the slides, is it safe to assume you didn't pull the emulsion tubes? They're designed to drop out from the bottom after removing the main jet, but most of the time they get so cruddy you have to push them out from the top.
 If you're going to remove the slides, save yourself some headache and push the emulsion tubes out and clean them. They're probably not the cause of the hanging idle, but the bike idles and runs much better when they're clean. Use a wooden dowel or chopstick to push them out.
'71 CB500 K0
'81 Yamaha XS650
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #17 on: April 12, 2013, 09:54:30 AM »
IW
Ah never heard of the propane torch method. Someone else mentioned using a propane torch on their carbs I thought they were nuts!
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline iron_worker
« Reply #18 on: April 12, 2013, 10:18:34 AM »
If your slides were very sticky and your return spring was weak it could possibly cause the whole thing to hang open slightly. It's definitely something to check. Especially if you were able to close them off my by hand.
x2 on cleaning the emulsion tubes if you're pulling the carbs anyway.
IW
Offline MotorFist
    • MotorFist
« Reply #19 on: April 12, 2013, 08:40:46 PM »
Well here I am again, scratching my head. I still can get this sorted out :(
I pulled the slides and emulsion tubes and cleaned them. Two of the emulsion tubes had a lot of gunk built up on the outside of them but the holes down the sides of them we are clear. I cleaned them all up and adjusted the needle clips to the middle position.
Put it all back together and no change.
Tried carb cleaner again for vacuum leaks with no results again.
The only thing I have gained with the bike through all this is it starts and idles much better than before. That goes for a warm or cold motor. But as soon as I start twisting the throttle, the hanging idle and occasional climbing idle starts.
Something I noticed is that when I first start the bike with a cold motor, the problems don't occur. It's only as the bike warms up. I know I read something in the carb FAQ about that. I better have a look again.
Also I can get the carbs synced and then snap the throttle a few times, and it becomes mildly out of sync again.
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
« Reply #20 on: April 12, 2013, 08:48:07 PM »
if the all of the carb passages also havent been blown through with compressed air any trouble from crud/dirt will remain,if the tubes had crud the carbs will aswell,the discharge port for the idle jet in the carb body isnt much larger than the actuall tiny jet itself!carbs cant be too clean,,also go right over your ignition,make sure the advancer isnt sticking.
Offline MotorFist
    • MotorFist
« Reply #21 on: April 12, 2013, 09:24:10 PM »
Thanks Dave. I did blow it out and the carbs seem to be clean. How do I check to see if my ignition advancer is sticking?
I just read the FAQ on checking timing and I used the spark method and it all lines up. But that doesn't mean that it might not stick?
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline MotorFist
    • MotorFist
« Reply #22 on: April 12, 2013, 10:15:13 PM »
I also just noticed that my 2&3 pipe have blued a lot more than 1&4. This is a new development. I remember being happy with how even they were last summer/fall.
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline K3Owner
« Reply #23 on: April 13, 2013, 05:58:52 AM »
Interesting video. I would attribute unstable idle to vacuum leaks or improper mixture but a blip on the throttle that hangs at 4000 would lead me to overly tight cable or at least something in the throttle mechanism. You say that you push on the mechanism and the idle returns to normal and you've removed the slides to check for sticking. I think you're at least in the proper area - almost definitely mechanical. You should find what is holding that throttle high. Ever disconnect the throttle cable fully to remove it from the equation? Sorry I can't be there to help.
1978 CB550K4 - yeah, I'm not a K3 Owner - my bad
« Reply #24 on: April 13, 2013, 06:12:42 AM »
if you have a strobe light,a simple rev up will show if the bleeding advancer is working or nought,,cafe racer lip alwright.what you #$%*in well lookinat you bleedin geezer?you wanna get funny boyo?
« Last Edit: April 13, 2013, 06:16:03 AM by dave500 »
Offline Scott S
« Reply #25 on: April 13, 2013, 06:25:10 AM »
 Are you sure it's not something simple like the rubber from the throttle grip rubbing on the RH control? I've seen grease on the handlebars get gummy and make the throttle not snap back as intended.
 Are your cables stock Honda or aftermarket? It looks like you have Clubmans or clip-ons....how is the cable routed?
'71 CB500 K0
'81 Yamaha XS650
« Reply #26 on: April 13, 2013, 06:33:50 AM »
yeah,,scotts a good geezer,hes alwright,know what i mean?check for any sort of like out of the ordinary,you know like the mods have been muckin about like,tamporin like with your frottle and so forth?"
Offline MotorFist
    • MotorFist
« Reply #27 on: April 13, 2013, 12:22:24 PM »
So I disconnected the throttle cables and ran the bike just using the linkage on the carbs. Still same problems.
I am going to pull the carbs again and recheck the pilots. I bought two aftermarket rebuild kits. One kit for my 500 and one kit for my girls 400. My 500 kit came with those little pilots and I never installed them. The 400 kit came with the longer #40 pilots and even have the logo on them. I am suspect of them after all this. They could be counterfeits after all.
I should mention that when I push down on the slide linkages to drop the idle, the only travel I get is a tiny bit from rested idle position down to the when the slides bottom out on the carb body. I don't think they are sticking. But obviously I don't know what the problem is! I REALLY appreciate everyone's help.
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline MotorFist
    • MotorFist
« Reply #28 on: April 13, 2013, 09:44:29 PM »
Well I pulled it apart and cleaned everything again. Also pulled the air screws and cleaned them again as well. Put it back together and it is running much better.
If i leave my Idle adjusted really low, like 500 rpm-ish it wont really idle well on its own but the hanging idle stays at 2000 rpm. It is turn my idle screw to where the regular idle is 1000 rpm, then the hanging idle goes up to 3000 rpm or so.
My slides are moving freely and my air screws are at 1 full turn out.
I went and rode it hard for 10 miles or so and it runs well despite a new intermittent flat spot at 1/2 to 3/4 throttle. I wonder if this is from moving my needle clip up to the center position? Or is it because it was cold enough to literally be snowing on my test ride?
I'm burnt out on it for the time being. It still isn't right but it runs well enough to ride. I will revisit this after a few days or maybe sooner if anyone has and advice.
I think I might follow Dave's advice and go buy a timing light and make sure that's right as well. I'm embarrassed to say that I'm almost to the point of taking it to a good local mechanic I know that has been working on SOHC's since they were new.  I really want to be able to fix this kind of stuff out with my own hands but I'm feeling a little defeated.
One thing is for certain, I learned how to thoroughly clean carbs!
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline Scott S
« Reply #29 on: April 13, 2013, 10:15:38 PM »
 You're Effing with the carbs and haven't set the timing? That's ass backwards. Carbs are LAST....after valve adjustment, cam chain adjustment, timing...hell, change the oil and filter and spark plugs....THEN start fiddling with the carbs.
'71 CB500 K0
'81 Yamaha XS650
Offline MotorFist
    • MotorFist
« Reply #30 on: April 14, 2013, 09:20:15 AM »
Yes it is I admit. The only reason I even messed with the carbs to start with was to replace the needle valves and bowl gaskets as they both leaked last summer.
The bike ran ok when I put it away other than the same hanging idle problem I have now. I just had to shut off the gas every time I stopped the motor and the carbs were leaking/messy.
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline chewbacca5000
  • I polish covers!
« Reply #31 on: July 01, 2013, 08:43:54 AM »
Thanks for posting this I was getting ready to drive this bike off a cliff.  Should be a crime to sell such lousy parts.  After market idle jet full 4 to 6 mm shorter than stock and has small little emulsion tubes. I was begging to thing that these carbs were somehow "special".  I kept thinking the idle circuit is so simple on these and is nearly identical to the cb750 so why I am I having such a hard time.
I read every post on this forum and one from Hondaman that basically said not enough gas.  Did everything double checked float height, checked for vacuum leaks, replaced / adjusted both throttle cables hopped on left foot and spun in circles nothing.... Until I read this post.  Got the kit for the needle valves and seat and used the pilot jets and did not think anything of it at the time.
Bike runs great but would die when I let go of the throttle.  If if was not for the dimples in the float tang doubt there would be enough fuel to do anything at all.
We'll anyway thanks a bunch!! :) :) :) :) :) :) :) :) :)
You know these things have a way of chipping away at you if you let them.
« Reply #32 on: July 01, 2013, 11:02:13 AM »
How do you know that each slide moves freely in it's bore along it's entire travel length?
Has the slide lifter linkage been dismantled since new?  Could there be parts missing, like the pivot ball "shoes"?
Has the throttle return spring been replaced with a weaker spring?
Is the spring using the original perch mounts?
Not smart to fiddle with carb tuning before the 3K tune up check list is confirmed.  Easily leads to frustration, imo.
Offline MotorFist
    • MotorFist
« Reply #33 on: July 01, 2013, 11:46:01 AM »
Hey all.  I never did post resolution to this thread and I apologize.  I ended up taking the bike to a local wrench/friend that has been working on these bikes for decades.  I had to go to Asia and needed the bike running when I got home for the relay.  He did end up adjusting the timing and also told me that my coils need replaced.  The plug wires have been trimmed so many times over the years that they can't be trimmed any more.  The looseness at the spark plug cap/plug wire is giving me a weak spark and had pitted my contacts on the points.
Biggest mistake was not doing as you guys mentioned and performing the 3000 mile tune up.  LESSON LEARNED!  Bike runs great now but I do need to look into replacing the coils.  I have seen so many threads about issues with guys running the wrong aftermarket coils that I am thinking of trying to find a good used set of OEM coils.  Any thoughts on this?
Thanks to all that chimed in and helped me
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
« Reply #34 on: July 01, 2013, 12:00:58 PM »
Why don't you just put new leads on you existing coils?
http://www.ngksparkplugs.com/products/performance/splicers.asp
Offline MotorFist
    • MotorFist
« Reply #35 on: July 01, 2013, 12:07:59 PM »
Well I guess that is an obvious solution :) I had no idea splicers existed. ThanksTT!
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
« Reply #36 on: July 01, 2013, 12:23:19 PM »
It is not easy getting steel strand core wires.  But, copper strand core seems to be available.
