Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Quote from: MotorFist on April 07, 2013, 05:32:04 PM I also changed the pilot jets as I could just not seem to get them clean no matter how much a soaked and sprayed and blew compressed air through them. When I rode it last summer it ran pretty good but I have always had a hanging high idle problem. And therein lies your problem. I went through the SAME thing on my CB500. It's the poorly designed aftermarket pilot jets. They're too short and don't stay submerged in the fuel in the float bowls. The holes are not the correct size nor are they spaced properly. You're idle is hanging because it's lean. It's lean because the pilot jets are crap. Find some genuine Keihin jets and try....I bet it will solve your problems.
