The discussion between IW and Fly is very helpful, thank you brothers. (I'll ignore the newbie remark :-) I did measure from the correct place, so thanks to all for your comments, very helpful also.
The bike does have the orginal air box, but PO installed 4-1 Magaphone exhaust. He may have changed the jets, I'll have to check on that. But could my following assumption be correct: If the PO installed larger dia. jet, he may have discovered he needed to raise the float level from the standard 1.026 to about .75 to try to reduce the fuel pressure....is this a possibility?
