I see you're in Texas. If you're still commuting this summer, I'd be more concerned. The key will be to keep a careful eye on the oil quality. As it deteriorates due to heat and use, change it. Make sure you're using a high quality oil; I prefer dead dinosaurs to synthetics but it may be irrelevant.
A more specific and fun experiment would be to get a temperature gauge for your oil, either permanently mounted or temporary. Record maximum oil temps coordinated with drive time temperatures, then consult detailed specs for your oil type and grade.
I have wondered the same thing, although I haven't commuted on my CB400F, I've done plenty of miles in stop and go over the past 5 years on my BMW. I'm comfortable finding a different route with less stops and traffic, keeping an eye on the oil condition. Definitely don't stretch or skip maintenance intervals.
