This is my first bike, a 1975 CB550. I have a couple buddies that know bikes, but neither ride a Honda. I have a few problems that we can't figure out.
First is the noise. I adjusted the valves twice. They are perfect. The second time was just to see if I messed up on the first time. I didn't. They are perfect. I changed the the oil and filter. The oil is topped off. So the noise... when it's running I'm getting a serious sewing machine tic coming from the valves. During the second valve adjustment I realized what it was. When carb 1 is at tdc, the rocker arms on all adjustable valves have side to side play. When you wiggle them side to side, they make the sewing machine sound I hear when it's running. When 4 is at tdc, same deal. Rocker arms have side to side play. Even when the bike is hot, the sound persists.
I took it out last night and while it was hot, it died on me. The oil and neutral lights were fading (which is the second problem I'll get to). It wouldn't crank on a kick or running pop. I pushed it 8 blocks home. After about 30 minutes of griping, I tested the battery and got 11.75 volts. And it started on the first kick.
One buddy said dying when it's hot sounds like a valve train issue, which brings me back to those loose rocker arms.
Problem 2. Earlier in the night I started it up and held it at 2 grand to get it warm. Reason being I'm firing on 3 cylinders until it warms up a little. Otherwise she craps out. Something sticking a float bowl, pulling carbs is coming up. I held it at 2 grand for a good long while at full choke, let off the throttle, and she immediately fell on her face and the battery was dead. Charged the battery up to almost 70%, put my gear on, fired it up on the first kick and rode away. Turned the choke off after three blocks. At every stop it felt like it was gonna die. Got to the pizza place I was heading to, and it finally died as I took a RIGHT (I'll get to this) to park. Came outside feeling pessimistic, but it fired up on the first kick. Rode 3 blocks and it died approaching a stop sign. Yes, petcock was open. It was pretty hot by then. Fading oil and neutral lights, not starting no matter how much I was killing myself trying to kick it and running pop it. Then pushed it the rest of the way home. And like I said, after 30 minutes, tested the battery and fired it up on the first kick with full choke. I immediately let off the throttle and she sat there idling just fine, albeit the sewing machine sound. I turned the bars to the left, fine. I turned the bars to the right, and she immediately died. So I have a bad connection somewhere.
My questions are: What's up with the rocker arms? Is that a normal old Honda sound, or is it a fix immediately it's killing your bike sound? And how about the battery dying? It's a brand new battery and seems to die and come back to life on a whim. Thought about charging it to 100%, riding for a couple hours, then seeing if it's holding a charge, but not if the loose rocker arms are bad to ride on. Finally, what about this electrical problem? Before going through everything to find the culprit, any idea what to single out that would cause it to shut off when turning the bars to the right?
I thank you in advance for your expertise. It's getting nice outside. I just want to be on it and not have to wonder if it's gonna die a few blocks from the garage.
Jim
