Okay so at my wits end here i hope someone can help me out. First the measurements of the old girl 1972 CB500, 105 main jets, 40 slow jet, 22 mm float height stock pipes and air box.
The bike was serviced by the dealer when the last owner (friend of mine) first got it. Inside of the carb looks perfect, i didnt touch the needles when I took it apart or crack the idle screws as I dont have an easy way to sync the carbs after since I live in an apartment, if i need to do anything with that I will have to rip them off again and figure out how to bench sync.
If I start the bike and leave it on less than a quarter choke it runs fine but as soon as i take it off choke fully i loose all power. I cant see any leaks in the system but the air filter is old, I am thinking of replacing it. Also one of the exhaust pipes has the rear plate that holds the baffle in rotted out but I dont see any other holes in the pipes. I was having one cylinder take a bit to fire when it was colder out but that was likely due to a leak in the system i have since repaired (my own fault, I left a clamp on one of the rubber adapters loose last year when I had the carbs off again).
Any help is much appreciated.
